Old 10-06-2002, 02:44 PM   #1
teeitup
Just like to part out trucks!!
teeitup's Avatar
4x4 Power steering ?????
I know this has been asked but I can't remember. I have a 67 and 68 4x4. Will the power steering unit off a 72 4x4 work on either one of mine? Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 10-06-2002, 07:40 PM   #2
jerry moss
Born Psycho
jerry moss's Avatar
it can be done but there are some modifications that must be made for it to function properly. i've done this same swap a few times but i always swapped over to a disc brake front axle at the same time. if you are interested you can call me and i'll explain how we did them- i type too slow to try and put all the information here,lol. my number is 925-634-2512 and i'm up til at least 9 p.m. ca. time, mon-fri i get home from work around 5 p.m.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 10-06-2002, 07:48 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Do the 4X4's have the same poblem as the 2 wheel drive when it comes to gear boxes?
Old 10-06-2002, 08:15 PM   #4
Alaskan
Truck'n the alcan
Alaskan's Avatar
Check out my web page. I did mine about 3 years ago. Not sure about the 2wd trucks.
68 GMC 4x4
71 C20 Custom Deluxe
83 1/2 ton conversion van
Alaskan is offline   Reply With Quote
Old 10-06-2002, 09:45 PM   #5
breeh
Recovering 67-72 Addict
breeh's Avatar
I ordered a kit from Rez Engineering to do this upgrade. I know that you can just bush the steering box out to make it work but I wanted to increase the rigidity also. These frames are prone to cracking with oversize tires. The kit includes two steel plates, one for the inner frame and one for the outside of the frame. I don't have their phone number with me right now but if you want it let me know and I will dig it up.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 10-06-2002, 10:00 PM   #6
teeitup
teeitup's Avatar
THANKS EVERYONE,
Jerry I'll call you about this later on. I have the disc brake frontend to put in also so I might as well do it all. I have to get ahold of my mechanic to see when he's free. THANKS again to everyone. All input is appreciated!!! I'll check out what everyone has done. Randy
1980 chevy swb 4x4
Old 10-07-2002, 04:23 AM   #7
Pont
I need another Barley Pop
Pont's Avatar
I have also done this swap on my 67. You will defintely need to space the steering box away from the frame or modify the frame to clear the buldge in the side of the steering box. As for the rest of the swap, I'm not sure what all is invloved if going with a stock type steering. I changed to a later disc Dana 44 and crossover steering when I did mine.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
