Saving 1 truck at a time!
Help with power steering pump.
I am trying to fit this power steering pump on my 283. I need a pulley that will drive the pump. It needs to have a groove at 5.00 inch spacing from the face of the block. The two grooves in the picture are at 3.25 and 3.75 so I still need the inner groove (3.25 inch) to run the alternator. I guess if I am using the wrong pump or mount braket that would help to know. Perhaps there is a different pulley for the pump that would work. Any help will be appreciated.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
its all about the +6 inches
Looks correct to me...except the part where the bullies don't line up.
If memory serves, your crank pully is not correct. My old Longhorn had the original set up, and it had a 2 pc crank pully. Your alt and pump mounting look to be correct. |
Andy, So all I need is an add-on section to my existing pulley? That would be nice. I have seen crank pulleys with like 4 or more grooves which is probably what I need.
It's been a while since I messed with the original pullies, (the GMC is set up with the newer pullies) but if memory serves....
Can someone confirm this for me? |
Transcendental Trucker
Yea, everything looks right, except for the crank pulley. It should have 3 grooves if it came with power steering originally. At least mine does..
Patrick Sullivan | sullivan@oregoncoast.com Rockaway Beach, Oregon 1972 Chevy Cheyenne C-20 1998 Dodge Dakota 4x4 So, fill to me the parting glass And drink a health whate'er befalls... Then gently rise and softly call Goodnight and joy be to you all! |
Patrick, I don't think just one groove will work since the power steering pump sits so far out...like another 1-1/4 inches from the second groove! It looks like I need a crank pulley with 4 grooves! Anyway...I probably have the wrong pump or bracket even though they bolt up. Perhaps there is another style of pump pulley that is offset to the rear to line up with the second groove.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 10-06-2002 at 08:28 PM. |
If I make a new pump pulley or spend $25 on one, I know the pump will be bad and I will have to start all over...LMAO!
Fabricate till you "puke"
I think all you need is 1 more groove......its 2 pcs , like the other longhorn said. the last pulley for the steer pump does set a ways out from the other 2. Its been a while for me also, i have been running later model pump,& accessories. I think if you had air, or add on air the crank had 4 pulleys. good luck crazy longhorn
Hmm.. here is a picture of mine.. it is stock as far as I know:
That looks right...it has to sit out a ways...like about 1 inch or so. Thanks...Randy is looking for one for me...but if anyone else has one laying around I will be glad to pay for it...providing Randy does not find one for me.
Ok, mine was inactive A/C...that explains the 4th one on my old set up.
I had a similar issue when I put a pump on my 327. I hunted the junk yards for days and finally found a pulley with the correct offset on a mid-60's full size car SB with the factory PS set up. Most of the newer SB PS setups are somewhat different. I think Fast has some of pullies sitting around.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
#13 |
![]() Join Date: Dec 1999
stllokn,theres a few different crank pulleys the flat one takes the long add on crank pulley,the Impala,Chevelle,early truck takes the short one,i have some Impala pumps and tons of crank pulleys,whatever crank pulley you need i guarantee to have it,cover the shipping and ill give you one.Thanks
Micah |
