The Original HotRod KnifeMaker
![]() Join Date: Jan 2007
How much time does it take to swap a bed on our trucks?
What all is involved? How muck fussing with wiring? It seems pretty straight forward but I thought I should ask BEFORE I get started? Thanks, Dave
Dave 69 GMC SWB 2WD 454 Turbo 400 |
Re: What, and how much time, is involved in a bed swap?
the wiring harness just unplugs, a ground strap or two and eight bolts.providing the bolts are not rusted to bad and don't require cutting or grinding off you'll be ready to lift it off in a half hour maby a little longer if you run in to some stubbern bolts or a 12 pack
common sense isn't so common anymore |
Back in the sticks
Not mention you need to have the bar-b-que going for the 4 guys that are going to do the lifting...and of course...
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
Saving 1 truck at a time!
If it has been on there longer than about a year...have an oxy/acet ready for those stubborn bolts/nuts. You might just as well get new rubber mount bushings too, while you are at it. Don't for get the ground straps...and like 71redcheyenne said...those 4 burly guys fueled with beef and brew...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
I've never had much trouble just spray pb blaster on the bolts and use a good impact!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
save the beer money just use engine crane an easy one man job
"Trucks with Class"
![]() Join Date: Jul 2000
The bolts are those square hole carriage bolts, so no power tools, or they will just spin. Use a pair of vice grips, so you can keep down pressure/tension on the bolt as you turn it. Most are not rusted bad and come off easy.
No rubber pads on factory beds. You can add them, but I don't know what they are supposed to do. Maybe quieter? |
