Size Matters
Side marker light retro fit?
OK guys this should be an easy one. I have a '69 longhorn with the regular reflectors on the side with no lights. I have heard that the delux lights from a '71-'72 will interchange but what about the lights? Do I just tap into the tail light/front marker light wires or is there some kinda adapter?
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ![]() ![]() |
its all about the +6 inches
Re: Side marker light retro fit?
yep, for the rear, tap into the brown wire, and the ground.
For the front, you can tap into just the running light wire (can't remember which one that is off the top of my head) and a ground, and they will burn steady. If you want them to blink in oposition of the fronts, then tap into both wires going to the front. The wire for the directionals, will act as a ground and light up the side marker, but when it gets power to it (when the directional is lit up) the ground will be taken away, and turn off the directional. Both ways is correct, I think 68 and 69's that were optioned with the lights were steady burn. I've seen '70 models wired both ways. I think in 71 they were all wired to blink |
Not a bad nut after all..
Not to hijack, but what was the last year for reflectors?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
Roadtrip!
![]() Join Date: Feb 2003
Badpeanut, i think sometime in 69 it changed. I have a set of the deluxe markers with out any light sockets in them and i don't think the deluxe started before that. Longhornman may know more about it as it looks like i may have an early 69.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
in 70 they all came with lights, 68 and 69 had lights optional, unless it was a cab/chassis with daulrear wheels, then they were required along with clearance lights... all at added cost over base equipment.
Size Matters
Cool! Thanks guys. One more thing....where do I get the bulb socket/pigtails and what bulbs are correct (as correct as they would be on a truck that came with them)?
Self-proclaimed LED man
The 194 wedge bulbs are the correct lights for sidemarkers both front and rear. You can buy the pigtail/sockets at O'Reily's for cheap. This is one alternative to changing the wiring in your truck. This method would need a dual element bulb of some sort though. I scavenged an underhood wiring harness and made a jumper wire. The blue/green wires would go to the sidemarker.
Justin
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor Last edited by 724x4a/cchevy; 11-01-2007 at 12:48 AM. |
194 buls is correct. 168 will fit and put out more light, but much more heat... I wouldn't go that route.
You can go to any junk yard and get your wires and plugs for a dollar each most likely. |
![]() Join Date: Jan 2005
I found a '70 in a yard with all the sidemarker harnesses, ripped them out and spliced them into mine. Now it is a "plug and play" setup as if it was factory.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
Size Matters
Thanks again for the information guys.
