HERE.......Somewhere
hole
what goes there such as an aftermarket part or an original part ![]() it really is bad when you smell the exaust smoke and feel heat.
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 ![]() ![]() Classics make it possible! |
![]() Join Date: Dec 2001
Re: hole
clutch rod- or clutch rod blockoff plate, as the case may be.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
![]() Join Date: Dec 2006
Re: hole
You should block that off to keep the heat out of the cab.If you are getting smoke/fumes,you should fix the exhaust leak and/or the oil leak.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
Nothing to see here.....
![]() Join Date: Jun 2007
Re: hole
mouse escape hole?
The master of disaster
Re: hole
No clue where at on the truck is this???
1994 Chevy Project in the works Life is like a jar of japalino's what you do today will burn youre a$$ tomorrow! |
its all about the +6 inches
Re: hole
that is on the lower drivers side firewall, towards the engine... down low.
As mentioned aboce, on manual tranny trucks, it had the clutch rod going through it. Automatic truck came with a plate to cover it, and I've recently been told the 67 - 69 actually had a plastic plug... which would explain why you NEVER see anything there on those year trucks... later ones had a metal cover. |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: hole
This help?
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Re: hole
so its a clutch linkage hole
![]() but is there some sort of item that goes there ![]()
#9 | |
Re: hole
BlahBlahBlah
Re: hole
You watch the for sale part of the board and wait for one to come up and try to jump on it...or per board rules you become a subscriber ( a measly 25 bucks a year ) and you can post a WTB ad looking for one. You actually get a lot more for being a subscriber. One of the mods can give you more info.
Re: hole
that line going through there goes to your mechanical aftermarket temp guage... it should go up to the head, or intake manifold.
The line isn't stock. |
Re: hole
I have purchased a few aftermarket ones on eBay (and have seen them at the local aftermarket guys place). It is a thin sheet of metal, cut in a cirlce, with a little lip on opposite sides to put two screws through.
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
#13 |
Re: hole
For a quick fix my mechanic put a tennis ball in one of my trucks.
#14 |
Re: hole
duct tape just kidding but better than nothing
common sense isn't so common anymore |
#15 |
Re: hole
if you're never gonna use it for it's intended purpose, the best fix would be to weld in a patch.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 11-01-2007 at 01:42 AM. |
#16 | |
Re: hole
Some of us are lazy though, and I personally like the smell of gasoline so Im keeping all my rust holes intact. Sure I get light headed but I like that feeling too.
