![]() Join Date: Jan 2001
Big Block Towers Work In 4x4?
Are the 2wd big block towers the same as 4wd ones? I am looking to swap out a 350 in favor of a 454 in a 4x4 long fleet.
Thanx, Bud |
Re: Big Block Towers Work In 4x4?
no there diffrent you will have to use the small block towers or buy an after market set up from diy4x or ORD.
Earl 68 2500 4x4 GMC Burb Last edited by earl87gta; 10-31-2007 at 04:35 PM. |
I thought so but I wanted to ask to be certain.
Thanx, Earl! ![]() |
I think they have a threadin the 4x4 section goin on now on big blocks in 4x4s.
Earl 68 2500 4x4 GMC Burb |
I am a Referee of life.
4X4's never came factory with a BB so there are no BB towers for 4X4 out there.The aftermarket has stepped up on almost everything though.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Born Psycho
![]() Join Date: Feb 2001
you can also use the cradle from a later 4x4-73-87 style-and use the clam shell type mounts. you might have to relieve the lower portion of the crossmember if it didn't come from a big block 4x4 otherwise the fuel pump will hit a little bit.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
