Lower Ball Joints
When replacing the lower ball joints, what's the best/easiest way to get them out of the control arms (assuming the arms are still on the truck) ?
Used Register
Re: Lower Ball Joints
I would use the C-Clamp style ball-joint press. You can buy them for around $70-$100 at Harbor Freight or get them on the loan-a-tool programs at AutoZone or other parts shacks.
Herb |
take them somewhere that has a press and get them pressed out.
I am a Referee of life.
I think I gave about $40.00 for the ball joint press I have at HF or NT.Looks like the ones I have seen for much more other places.I will be using it in a couple weeks.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 10-31-2007 at 07:25 PM. |
I miss this truck.
When I did this, I had absolutely no luck getting the ball joints out, even with the press. On my '71, the press would not open wide enough to get around the joint. I may have been misusing the tool, its hard to say. For just a little more, I went ahead and took the control arms out, replaced all the bushings, and had a front end shop press the old bearings out and press the new ones in while I had the arms out of the truck.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
Semi-Senior Member
A large BFH (big friggen hammer) will usually get them out. Use a bottle jack or jack stand under the control arm, get the spindle out of the way, and start smacking the joint straight out the bottom. Now you'll likely need the press to get the new ones in.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab |
I miss this truck.
Yeah, I tried the BFH before I went and got the press. All I could accomplish that way was shaping the end of the stud like a mushroom.
Chinook Arch
Here's how I've done it, and have been 95% successful:
Remove cotter pin from ball joint, and loosen nut off but don't remove. Now take a good sized hammer, and smack the spindle on the flat along where the ball joint runs through the spindle. The spring will keep tension on the ball joint, and once it moves, put your jack under the ball joint, remove the nut, and slowly lower the jack - usuallly only takes 2-3 smacks, and sometimes a little penetrating oil. I always see the guys on T-V using the pickle fork, which works, but usually destroys the rubber boot in the process. This works for steering joints, too!
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus. Elsie's truck 2.5" dual exhaust with Hooker Aero Chambers Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350 ECE drop 3.5/5 Last edited by Elsie72; 11-01-2007 at 01:38 PM. |
bought this press from jcwhitney about $40-$50 a number of years ago works great on pressed in ball joints. ujoints, trailing arm bushings ,panhard bushings, 4bar bushings and a number of other things that i dont recall
when using th BFH method you don't want to hit it on the end of the stud lay the ball joint back towards the spring & hit it on the boot/ball area
& as long as you don't swing like a girl it should be out in 2 -4 hits. I've removed 100s this way without any problems. You will need a balljoint press to install the new part.
#11 | |
Semi-Senior Member
I've done 100s as well. The key is having the control arm solid on the jack or stand. any bounce in it will cancel your BFH hit.
Great Topic .. I was just about to tackle this project
Jeff 1967 GMC 3/4ton LWB, Orginal Straight 6, 4 on the floor Project truck ![]() |
#13 |
I used something similar to cdowns tool, big C clamp with a couple of different sized pipes. Found the correct size, hit it with the impact, popped the old out and the new in in a 3 minutes, same for the other side, easy as cake!! Autozone has a loaner program or do the harbor frieght if you ever plan to work on more than one vehicle in your lifetime.
