Old 10-31-2007, 04:21 PM   #1
dhughins
dhughins's Avatar
height difference
i lowered my truck with a 3/5 spring flip kit drop. and i dont believe it was level before. i measured it now and my front drivers is near 31 inches @ middle of fender my back passenger is near 28 inches the other 2 are somewhere in between how do i measure correctly and if it is off how do i correct?
dhughins is offline   Reply With Quote
Old 10-31-2007, 09:15 PM   #2
beaterC10
Re: height difference
The front wheel wells are higher than the rear, I think normally by at least an inch. I have seen 1/2 - 1 inch variation side to side on the two trucks I have dropped. The variation can be from the springs, body mounts, tires, etc. Without the before drop measurements it's a bit of a challenge to determine the amount of drop. Gues the important thing is if you are happy with the results.
beaterC10 is offline   Reply With Quote
Old 11-01-2007, 05:39 PM   #3
dhughins
dhughins's Avatar
the drop is fine i dont have any issues with it but i'm wondering how to tell if its level and if not how to fix it.
