Old 10-31-2007, 04:40 PM   #1
blk81shrt
blk81shrt's Avatar
Home Made Flip Kit
Hey guys, I was wondering if instead of buying a DJM/Belltech flip I could make my own with just with some blocks and u bolts? I would just flip the axle and then bolt the u bolts upside down around it. Would this work? Are there any tabs or anything on the axle that would prevent me from doing this?
blk81shrt is offline   Reply With Quote
Old 10-31-2007, 04:45 PM   #2
FlatBrokeRacing
FlatBrokeRacing's Avatar
Re: Home Made Flip Kit
I tried to do the same thing and just don't have all the materials needed. It is a lot easier to buy it.
I understand that money don't grow on trees.
If you attempt this, remember that the axle has to be located 1 in. back.
FlatBrokeRacing is offline   Reply With Quote
Old 10-31-2007, 05:06 PM   #3
blk81shrt
blk81shrt's Avatar
Why do you need to locate it back 1"??
Old 10-31-2007, 05:26 PM   #4
SCOTI
SCOTI's Avatar
When the axle is lowered that amount, it shifts the rear-end forward. That by itself isn't a big deal, but it also shifts the driveshaft forward into the trans further than ideal. All it takes is one good whack & the trans is hurt....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-31-2007, 07:09 PM   #5
blk81shrt
blk81shrt's Avatar
Alright cool... I think ill use the kit, that way ill have the pinion adjusters built in.. Any thoughts on shock relocators? The kit comes with some but do they work well? I need new shocks anyways should i just buy shorter ones?
Old 10-31-2007, 07:15 PM   #6
SCOTI
SCOTI's Avatar
If they're part of the kit it's a no brainer. If you have to purchase them separate, they're worth it if you plan on using off the shelf shocks. If you're going to use custom 'drop-shocks', you could prob skip using them.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-31-2007, 07:37 PM   #7
Bad Karma
Magnificent bastard
Bad Karma's Avatar
If you can weld, get some new spring perches, drill a new hole however far away it needs to be for the pin, and weld them to the bottom of the tubes. Cheap and easy.
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 10-31-2007, 09:44 PM   #8
blk81shrt
blk81shrt's Avatar
well the kit comes with them but i would still use nitro shocks. Would I have a better ride with or without the extenders?
Old 10-31-2007, 10:48 PM   #9
SCOTI
SCOTI's Avatar
There's no right or wrong answer here.
You need to know what length shock that's required for your combination of parts ride height. Compare that to the compressed & extended lengths of the 'nitro' shocks. You want the shock to be as close to its center of travel as possible when sitting still @ ride height. If it's close, you won't need extenders. If the shock is too compressed, the extenders gain some of the travel back.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-01-2007, 04:36 AM   #10
impala_631
:( BYEBYE :(
impala_631's Avatar
i made mine in about 20minutes with some scrape steel, i used a a peice of 2x3 tube, cut the shape of the axel with a torch then cleaned it up with a grinder and welded it in, no problems
impala_631 is offline   Reply With Quote
