Old 10-31-2007, 06:24 PM   #1
71 super
71 super's Avatar
sm465 and NP205 questions
I just pulled 465/205 out of frame so that frame could be cleaned/blasted and painted. I pulled bell and trans/case as a complete unit and then broke them down out side the frame. There appears to be a gasket of some type between adapter and trans and another between adapter and t/case where can I find these new- previous owner used rtv. 2nd question - what is the easiest way to put these parts back in. I am buying a new motor and the clutch is goig to be replaced as well (frame off) but these things are heavy! Any advice is welcomed. Thanks 71 super- p.s. I am a 4x4 newby- everything previously has been 2wd.
71 super is offline   Reply With Quote
Old 10-31-2007, 07:22 PM   #2
DieselEater
DieselEater's Avatar
Re: sm465 and NP205 questions
rent a good transmission jack.......its worth it!!! You should then be able to lift it all up at once and move it around enough to fit it all where you want it. put the cross members on the tranny first.
A........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 10-31-2007, 07:38 PM   #3
Ace in the hole
as for the gasket, you will probably only find them in a set with all the other gaskets that you would need for a trans rebuild. That's probably why the PO used rtv, didn't want to spend the money on a complete gasket kit. I just bought one for mine because I was tearing mine down and going thru it. Seem like it was in the neiborhood of $20
dieseleater- there is a trany crossmember for a sm465/np205 set up? thought the only member was what the adapter bolts to.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 10-31-2007, 07:59 PM   #4
earl87gta
earl87gta's Avatar
I use an engine hoist to lift them in to position from inside the truck I find its easier then a trans jack is and nothing will be in your way under neath when your lining every thing up on the engine.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-31-2007, 08:27 PM   #5
DieselEater
Yeah, that's the one I was talking about...
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
Old 10-31-2007, 09:43 PM   #6
Southedisto
River life......
Southedisto's Avatar
X2, makes for an easy install.
As for the gaskets, I cut my own out of cork material.
Southedisto is offline   Reply With Quote
Old 10-31-2007, 10:07 PM   #7
71 super
71 super's Avatar
Thanks guys I appreciate it!!!
Old 10-31-2007, 10:54 PM   #8
kwmech
The gaskets are available from the dealer
Old 11-01-2007, 05:51 AM   #9
68K20 x Drill
2 crappy transmission jacks works pretty well too.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 11-02-2007, 12:55 PM   #10
Erl
Erl's Avatar
Quad 4x4 has them.
ERL
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
