I-6 towers and V-8 tower differences?
Hey guys I was hoping to toss my V8 in tonight but I was wondering if there is a difference between the V8 towers and I6 engine towers? Thanks
![]() Join Date: Feb 2003
Re: I-6 towers and V-8 tower differences?
I used the I6 towers to install my SBC. They set the motor back about an 1-1/2 or 2 inches and maybe a little lower. I measured this once but don't remember exactly. It makes an HEI a little tight back there but no issues. I wanted the motor back as far and low as possible for center of gravity reasons.
The 292 uses staggered mounts and won't work. Last edited by Chevy4Life; 10-31-2007 at 07:15 PM. |
![]() ![]() Join Date: Jul 2002
Far as I know that is about the only difference between the I6 and SB towers is how the holes are made to where they bolt onto the frame.
As mentioned if you use the I6 towers it will set the engine back. Your distributor will be tight, but should clear fine.
Life, Be In It.....
![]() Join Date: Oct 2003
I did the same thing, only after I had my inline 6 towers powder coated. There is the thread I started with some pictures of v8 towers installed. I hope it helps. The motor sat a little too close to the firewall for me, so I bought V8 towers.
http://67-72chevytrucks.com/vboard/s...d.php?t=228793
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
![]() Join Date: Sep 2006
I have a 305 in mine on I6 towers. I was hoping to switch them out. Anyone know if this will cause any problem anywhere else? i.e. tranny crossmember or driveshaft length
BRENT ![]() -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
![]() Join Date: Nov 2004
Towers are completely different. V-8 towers won't mount in the I-6 location and vice versa. They mount at different points on the suspension crossmember (the v-8 to the front and the I-6 to the rear) and because of the crossmember mounts, they are angled/shaped differently which makes them not interchangable between the two locations.
BUT you can mount a v-8 in the I-6 position. As stated above the dizzy is just really close to the firewall.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Switching them out will require you moving the engine a couple inches forward, which would mean a lengthened driveshaft. If you have a manual I don't know if you can do this, because you can't move the 3 speed crossmember forward. If you have an auto or a manual with the rear crossmember, the crossmember will need to move forward.
