Old 10-31-2007, 08:25 PM   #1
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
70 3/4 ton 4 x 4 drum to disk question
Has anyone converted a 3/4 ton 8 lug Chevy 4 x 4 front drum to disk? Reason I'm asking is I looked at one site and it looked like All was needed was the backing plate, calipers and it looked like the rotors slipped on just like the drums currently do. It almost seemed too easy unless I am missing something.
Thanks!
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 10-31-2007, 08:28 PM   #2
duallyjams
duallyjams's Avatar
Re: 70 3/4 ton 4 x 4 drum to disk question
Is you rear a open or closed knuckle
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 10-31-2007, 09:12 PM   #3
Sir Fisher
Sir Fisher's Avatar
good question; i've been wanting to ask myself too; you just beat me to it... i have a closed knuckle front end. here's a pic of the knuckle and the hub.
thanks,
ww
1970 Chevy K20 Custom Camper
1996 Chevy Impala SS
2008 Chevy Avalanche LT3
2003 Honda Accord EX
2001 Hewes Redfisher 16 Fighting Lady Yellow
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118
Sir Fisher is offline   Reply With Quote
Old 10-31-2007, 11:22 PM   #4
Old Chevy Mech
Keepin it runnin!
Its the bone stock open knuckle dana 44. I'd bet the only difference between the 1/2 ton version & the 3/4 ton version are the hubs! lol
Frank
1970 K-5 4X4 Blazer
Old 11-01-2007, 12:00 AM   #5
brianthelion02
Overdrive club
brianthelion02's Avatar
I tried putting disc brakes on my 69 closed knuckle axle,they will bolt on but the inner axle will need some machining to make it work!!!!!!I found it easier to buy a set of axles from a 72 and bolt them in!!!!!!!
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 11-01-2007, 12:46 AM   #6
earl87gta
earl87gta's Avatar
If you have the 70 open knuckle axle you will need from the knuckles out for the convertion. if you have the closed knuckle axle like in the pic above the only cost effective way is to just get an axle from a newer truck and swap it in.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 11-01-2007, 06:55 AM   #7
Old Chevy Mech
Keepin it runnin!
Earl,
Do you mean that the knuckles have to be replaced? I went to Blackbirds Custom Trucks
site and it looked to me as though it was pretty simple (depending on your level of pain, mine is pretty high)
Frank
1970 K-5 4X4 Blazer
Old 11-01-2007, 08:03 AM   #8
OLDCHEV4X4
OLDCHEV4X4's Avatar
The bolt circle that the spindle bolts to on a drum brake knuckle, is clocked differantly than a disc brake knuckle. These bolts also hold the disc brake caliper mount on. So if you have a open knuckle d44 disc brake axle, swap everything from the knuckles out, onto your drum brake axle.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 11-01-2007, 01:04 PM   #9
earl87gta
earl87gta's Avatar
The black bird kit is a custom job so its alittle difrent. the cheepest and easest way will be for you to get a hole 3/4 axle from a 71 up truck with disk breaks and just switch from the knucles out. you should be able to get what you need for around $150
Earl
Old 11-02-2007, 08:02 AM   #10
Old Chevy Mech
Keepin it runnin!
Here is the hub.
1970 K-5 4X4 Blazer
