Old 10-31-2007, 09:17 PM   #1
Richard Dobson
Heat Temp Sensor?
I got my 396 engine started a let it run for approx 15 minutes with no movement on the temperature gage. I have put in a new 180 deg thermostat, new alum water pump, new hoses. I have a 4 core rad. Have I let the engine run long enough? The hoses were hot, the rad was hot, so I was concerned when the temp gage showed no movement at all and shut the eng off. I ran a wire from the temp sending unit to a bolt on the intake and had the wife watch the temp gage and it pegged out to the hot position. Does this mean the sending unit is bad? Thanks for all replies.
Richard Dobson
Richard Dobson is offline   Reply With Quote
Old 10-31-2007, 09:49 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Heat Temp Sensor?
Sounds like a faulty sending unit to me.
If the rad and hose are warm, or hot, then the engine is certinaly warmed up.
By grounding the sending unit, you tested the wire and guage, and they responded correctly by pegging out.
Old 10-31-2007, 10:20 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
By shorting the temp sender to the block you bypassed the sender to ground resistance.
This shows that 1. You have a bad sender or 2. the sender is not connecting to the ground (cylinder head ). Try running a jumper from the sender housing to ground and if you get a reading it means the sender is not grounded good. Did you use any sealant on the sender threads?
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-01-2007, 08:24 PM   #4
Richard Dobson
Yeah, I used teflon tape. I bought a new sending unit put it on a it works fine. The only thing is I need the little thingy that goes on top of the sending unit for the electric lead to attach to. Regards
Richard Dobson
