11-01-2007, 01:26 AM | #1 |
New shifter?
Is there a place to buy a new gear shifter for the SM465 4 speed tranny? Mine is VERY worn out and I have found little info on repairing it. The very bottom "snout" wobbles badly, giving the shifter several inches of slop when in gear. Thanks!
Colby. |
11-01-2007, 01:37 AM | #2 |
Re: New shifter?
Have you removed the shifter to inspect it?
I don't know about this specific transmission, but most have a soft bushing to eliminate wear on the hard parts. When it wears out, gives the slop you mentioned. Just my $0.02
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
11-01-2007, 01:42 AM | #3 |
Re: New shifter?
I have removed it, most tranny's I've worked on have a solid, one piece shifter. This one has a snout that fits into the bottom of the shifter stem, and it flops all around. It looks like it should have a bushing or something inside of it but I don't know. Any thoughts?
11-01-2007, 01:56 AM | #4 |
Re: New shifter?
don't know if it will help, but here's an exploded view
The corresponding parts list can be found HERE
11-01-2007, 07:24 AM | #5 |
Re: New shifter?
Sorry, I dont know the way to make a direct link. This helped me out.
http://www.pirate4x4.com/tech/billav...465/index.html
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" Last edited by eric67m; 11-01-2007 at 07:27 AM. Reason: link not working |
11-01-2007, 02:30 PM | #6 |
Re: New shifter?
Thanks for the replies!
I have seen the Pirate4x4 info before, but it doesn't talk about the problem I'm experiencing. I'm gonna check with a tranny shop and see if they are familiar with this, and I might check some wrecking yards for a better shifter. |
