11-01-2007, 07:33 AM | #1 |
Right turn Clyde
Stock radio wiring diagram help
I'm trying to get a diagram of the wire colors and what they are. Its a 12 point harness for a 1984 Silverado with front and rear speakers. I have some figured out other than the polarity.
Blue connector: Light Blue wire / Dark Blue with Light Blue stripe Driverside rear speaker Yellow / Brown with Yellow stripe Passengerside rear speaker Clear connector: Light Gray wire / Tan wire Driverside front speaker Dark Green wire / Light Green Passengerside front speaker Black connector: Light Yellow wire / ?? Light Gray wire / ?? Black wire / Ground So if I could get the polarity for the speakers front and rear. Then the light yellow wire and light gray wire for the black connector.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
11-01-2007, 10:21 AM | #2 |
Re: Stock radio wiring diagram help
Maybe this will help - http://www.installdr.com/Harnesses/GM-Wiring.pdf
Most all GM vehicles use the same color codes.
- Greg |
11-01-2007, 11:13 AM | #3 |
Right turn Clyde
I was looking at that site but it doesnt seem to all match my harness.
