Old 11-01-2007, 10:34 PM   #1
Yatzee
Opinions Needed...and a pic
I posted a question about my rear end before but can decide what the best solution for my problem is.
I Have a 327 w/ a 3 speed AT and 4.11's. The issue is I do a lot of freeway driving and this setup isn't working for me.
I've looked for a 3rd member with milder gears to swap and can't find one. I also called around to rebuild my 3rd member and I have been told its hard to find the proper gears for a stock 1962 housing, is that true?
Another option I am thinking about is putting in a 4 speed AT w/ OD so I can still have my lowend torque and be able to cruise on the freeway.
What would you do if you want the best setup for a cruiser but are on a limited budget? Also what do you think it should cost for the different options if I remove/install the parts but have a shop rebuild the gears or find a used tranny?
Thanks, Alex
And heres a pic...
Yatzee is offline   Reply With Quote
Old 11-02-2007, 12:04 AM   #2
NF65Fleetside
NF65Fleetside's Avatar
Re: Opinions Needed...and a pic
Saw a guy out of Palmdale on the HAMB selling a complete 700r setup for $300. Not sure if he still has it....heheheh Ill take your 411 though if you swap!
NF65Fleetside is offline   Reply With Quote
Old 11-02-2007, 12:51 AM   #3
Yatzee
I'm gonna sound like an idiot, but whats the HAMB? Oh and don't laugh about a rear end swap, what ratio do you have?
-Alex
Old 11-02-2007, 01:00 AM   #4
NF65Fleetside
H.A.M.B....Hokey Ass Message Board, its a old timers hot rod forum. www.jalopyjournal.com/forum thats the link to it. The guys on there are kinda brutal unless your sporting a 30's highboy or some type of Boyd/Foose rod. BUT their classifieds are always full of really good parts and cars for sale.
Im not sure on what rear I have but I know for sure its not 4.11!! Its a half-ton so Im thinking 3.33?
Old 11-02-2007, 10:12 AM   #5
jchav62
1962 C-10
jchav62's Avatar
A good 700r4 would be your easiest solution. I'm not sure, but I don't think ring and pinion gears for a 62 rearend are too available... The later 12 bolts are more common. With little modifications you can use a 72 rearend. 3.08 gears with aTh350 is a good highway setup.
Beautiful truck by the way!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 11-02-2007, 10:35 AM   #6
62ChevyStep
62ChevyStep's Avatar
I agree, 700r4, I am running a 72' rear with one and 3.73, crusies 70+ all day at 2010rpm.
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 11-02-2007, 11:07 AM   #7
chevy_mike
Never Ending Projects
chevy_mike's Avatar
When I had my '68, it had 4:11's and a 3 speed AT. I put a 700R4 in and cruise RPM's were just under 2200. The only thing I didn't like about a 700R4 is first gear is 3.06. With the 4:11, it would smoke the tires really easy in first and you were not in first very long. I want to do a 200R4 in my '64 since first gear is about the same as a TH-350.
Other idea is find a different rear end at the junk yard that has lower gears.
My .02 worth.
chevy_mike is offline   Reply With Quote
Old 11-02-2007, 11:30 AM   #8
04Xrider
Registered thread killer
04Xrider's Avatar
Why not swap the whole rear end out for something more suitable, like a 3:50, or 3:73?
!966 stepside, 350 SB, ZZ-4 roller, Crane roller rockers, 0.030 flat tops, airgap intake, 750 Holley, stainless steel headers, edelbrock SDT mufflers, Mark 8 elec fan, 700R-4, column shift
04Xrider is offline   Reply With Quote
Old 11-02-2007, 12:34 PM   #9
jchav62
1962 C-10
jchav62's Avatar
I'm running 3.73's with a th350 and a GearVendor Overdrive. It's perfect. I like the GearVendor because I still have the quick shifting of the 350 and still have an overdrive. I wish the 700's would shift a little quicker and firmer. Maybe there's a way...
Joseph Chavez
Old 11-02-2007, 08:01 PM   #10
Iron-Butt
454 club
Iron-Butt's Avatar
I have a 454 / 400 auto in mine with a 72 308 rear end and it cruises all day long with no problems.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 11-02-2007, 08:44 PM   #11
NF65Fleetside
could someone post a link of rear gear sets for the 60-66' years? Im clueless as to what I have and also what I cruise at on the freeway
Old 11-03-2007, 09:02 AM   #12
chevroletrestoguy
You may want to try DTS. Thats www.drivetrainspecialists.com
I just ordered a new 3.08 eaton posi and ring and pinion along with a rebuild kit. They told me it would work in a 65, I'm not sure about a 62.
chevroletrestoguy is offline   Reply With Quote
