Old 11-01-2007, 10:36 PM   #1
humanspeeddemon
Question Question regarding a th350 swap.
I need help with the 3-speed to a th350 swap, will the crossmember bolt up,and is the driveshaft the same? its a long boxbut its a 2 pice driveshaft. Thanks for the help.
humanspeeddemon is offline   Reply With Quote
Old 11-02-2007, 04:51 AM   #2
JimKshortstep4x4
Re: Question regarding a th350 swap.
The driveshaft will interchange. You will need the automatic cross member to support the rear tranny mount and the holes should be in the frame.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
