Old 11-02-2007, 02:43 AM   #1
hewlett2002000
hewlett2002000's Avatar
got a question..... see through valve covers...
i was sitting here, cant sleep, bored as hell. for some reason i closed my eyes and saw rocker arms moving as an engine was running.... real gear head huh? lol well i was thinking of making see through valve covers for my truck. i think that would be cool. how could i make some that would stand up to the heat? i was just thinking of installing a little window in the top of some spare covers i have laying around. any ideas on what kind of material to use?
thanks,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 11-02-2007, 02:51 AM   #2
NF65Fleetside
NF65Fleetside's Avatar
Re: got a question..... see through valve covers...
that would be an awesome idea, and yes only a true gearhead would think of something like that...my concern is that wouldnt too much oil sling around make the covers non visable after awhile?
NF65Fleetside is offline   Reply With Quote
Old 11-02-2007, 03:48 PM   #3
sls_06ion
pyrex, and theres a company in california that will do it for you. plus they have a way of securing it to the vavle cover.
http://www.killerglass.com/ - these folks do it...
sls_06ion is offline   Reply With Quote
Old 11-02-2007, 04:08 PM   #4
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
I agree that's an interesting idea. I thought I had seen it on the web somewhere before but I couldn't find it through a quick search. Pyrex would be the way to go, it won't stain like plastics and as long as you keep your oil clean everything should be plenty visable.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 11-02-2007, 05:02 PM   #5
salazar44
65 - Chevy C10
salazar44's Avatar
I think it has been done already. Search and you might find some already made??
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 11-02-2007, 07:45 PM   #6
Chevysdominate
Chevysdominate's Avatar
You should have no problems using a sheet of lexan (polycarbonate). I could be wrong, but i believe the upper temperature range is 300 degrees. You can get some at home depot or lowes and its cheap.
Chevysdominate is offline   Reply With Quote
Old 11-02-2007, 07:46 PM   #7
Iron-Butt
454 club
Iron-Butt's Avatar
Neat idea.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 11-02-2007, 08:22 PM   #8
mbgmike
We sell the clear differential cover that would go with it. Its not cheap.
We used to press form plex and lexan. All you would need to do is make a wooden cover or screw an old cover down to a raised stand.Make two 1/4" plates of aluminum with a rectanglular hole that are bolted together with the plastic sandwitched in between. Heat the whole thing up in an oven to 350 degrees and when its ready yank it out and press it down over the mold and clamp fast You would probably have to squish in at the sides for the earlier covers maybe using some dowl rods.
Of course casting it would be less work.
I am going to go drink beer and think about it
mbgmike is offline   Reply With Quote
Old 11-03-2007, 10:26 PM   #9
Dadsredwagon
Dadsredwagon's Avatar
seen it on a 72 Chevelle, after a while the clear is not very cleat looks great while it first starting but the cover get oil slinged everywhere, just my 2 cents
Dadsredwagon is offline   Reply With Quote
Old 11-04-2007, 03:11 PM   #10
sls_06ion
this company also does radiator hoses, if you want this I'd suggest pyrex it can be treated to shed oils, my.02
Old 11-04-2007, 06:59 PM   #11
19GMC63
19GMC63's Avatar
it would be really cool if they were removeable, so you could clean them, or to make adjusting lifters easier.
19GMC63 is offline   Reply With Quote
