Intake and carb swap
I am going to pull the truck in the garage in a few weeks and put dual exhaust on it to wake up the neighbors. It currently has the original 2bbl carb and I am considering a 4bbl swap when i do the exhaust. My question is will a 4bbl make a significant power difference? Any suggestions for an intake and carb to use? the truck is a 307, 4spd, 410 rear, 3/4 ton. If i do a intake swap, what else should I be doing besides a HEI ignition? I am not goiing to put a cam in it until i rebuild the motor, hopefully in a few years.
Re: Intake and carb swap
I'd go Edelbrock on both the intake and the carb. Headers and HEI will round it out nicely. I have this exact combo on my truck.
FYI, the 1405 has better power than the 1406 when it comes to carbs. It has slightly bigger jets in the primaries.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
The swap to HEI will likely get you more power than the 4bbl conversion will, but i would expect a 30 - 40 hp increase if your engine is in otherwise good condition, for the whole combo (Performer RPM intake, carb, a well built set of headers, and HEI )
Ill concur with what they've said- though I prefer the 1406 on a DD. Run an RPM edelbrock intake (or the Wiend Team G if you prefer), and go with a Summit brand HEI dizzy. A set of Hooker comp headers are cheap from Northernautoparts.com and you will enjoy the performance increase with little change at all in fuel economy- perhaps even an increase.
As far as the 1405 performing better... everyone should have a jet kit and tune their carb to their preferences. However, Edelbrocks are known for running well right out of the box. I ran a 1406 on my SBC for years and never touched it until I got into racing.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
