Running Rich
Ok it's a 72 C10 with a 383 Stroker, it has a manual choke 600 holley and has the HEI Dist. It is getting 12.46 volts to the dist so getting the juice it needs for that. But when I start it up it has a VERY strong gas smell coming from the exhaust. I know the timing needs to be tuned in more (at 35 past TDC right now and was told closer to 46) but does anyone have any suggestions?
I have ordered the vapor canister to hook up to it since the original was toast and have the idle mixture screws at 1 1/2 turns like the manual states but it is just baffling me right now on how to fix it. Any help is greatly appreciated. Thanks |
Re: Running Rich
What is your timing set at idle with vac advance unplugged? That's the first place to start. 46 is alot of total advance for most motors. Stock HEI's do not pefrom well on higher hp motors. Are you using the choke at all at start up?
Set the idle screws as far in as you can without it stalling after you set the timing.
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
Re: Running Rich
The timing right now is 35 with advance hooked up. The dist is a stock one with performance guts added (module and such). Choke is wide open and 1 full turn out is the best I can get before the engine starts trying to stall out.
Will try and set the timing tonight with the vacuum disconnected and see what it'll do. Thanks |
Re: Running Rich
When you say 35 with advance hooked up you mean 35 total right. Not 35 at idle.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Re: Running Rich
I mean with the truck running at idle speed and vacuum still hooked up it's at 35.
Re: Running Rich
35 is suppsoed to be the max timing when you rev the motor to say 3500-4000rpms. at idle you should be somewhere between 6 and 12, give or take a few degrees depending on your set up.
that should be your problem. however i am experiencing the same issues as you where i can't adjust the idle screws out more than 1 full turn without the engine dieing. if you still have the problem after you fix your timing, there is furhter tuning to be done inside the carb. |
#7 | |
Re: Running Rich
#8 | |
Re: Running Rich
Re: Running Rich
Ok home now and just did some tuning, anything below 25 degrees the engine bogs down and tries to die, right now carb is 1/2 turn out and throttle response is great but still very strong fumes. I have a 600 manual choke holley and it doesn't have the fuel bowl adjustment on it.
Any other ideas why it might be running so rich? Thanks for all the help ![]() |
Re: Running Rich
do you have a stock fuel pump
Re: Running Rich
It has a Holley 80gph fuel pump on it.
laying low
![]() Join Date: Mar 2001
Re: Running Rich
And a fuel pressure regulator? And set at what?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#13 |
Re: Running Rich
No regulator on it, bought a stock fuel pump new for $20 so going to give that a shot, if not it then only out $20.
#14 |
Re: Running Rich
Ok got the new stock fuel pump and installed it, helped alot but still running a little rich. Timing is set at 25 pdc (any lower and it tries to die) and carb is 1 turn out, seemed to run best at that.
Any other ideas? |
#15 |
Green club
Re: Running Rich
25* at idle?
If so, what is your idle speed and how far do you have to set the idle speed screw to keep it running? If you have a smaller cam, this will run very irratic at that timing setting. Big cam in the engine, this may be needed but even my .630 lift cam in the Chevelle only wants 15 or so to be clean at 1100. There are a few things that will make a Holley run rich: Excessive fuel pressure Blown power valve Too much initial idle adjustment cranked to keep it running (exposing the transition slot pulling in fuel from the main circuit) Check to see if turning the idle screws in until it dies. If it does not recheck everything I listed. Idle screws cranked out to far. Too high of a float setting, look down the carb at idle and see if there is any fuel dripping out of your boosters, if there is a power valve or float setting is amiss. Now, on a side note, Holleys are inherent to run rich right out of the box. there is not much you can do about that except fooling witht eh bleed sizes and I would highly discourage that.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
