Old 11-02-2007, 03:03 PM   #1
tk1251k
tk1251k's Avatar
Cool oil drain plug
I cannot get oil to stop leaking from drain plug. I changed washer to a plastic type or something still leaks after tightening alot. What is the best washewr to use.
tk1251k is offline   Reply With Quote
Old 11-02-2007, 03:18 PM   #2
smoked68
smoked68's Avatar
Re: oil drain plug
I dont know about the truck but i had a crack in the oil pan at the drain hole on my bike. Got that fixed and the drip went away. On the truck though I use an aluminum or plastic one, either has worked fine. Some of my buddies like the copper...
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 11-02-2007, 03:20 PM   #3
smoked68
smoked68's Avatar
Re: oil drain plug
Oh by the by, with that crack in the bike pan, the tighter the more it leaked. Good luck......
Old 11-02-2007, 07:53 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: oil drain plug
Originally Posted by smoked68 View Post
I dont know about the truck but i had a crack in the oil pan at the drain hole on my bike. Got that fixed and the drip went away...
I had the same thing on a truck I used to have. It was a small crack in the weld on the drain plug. I took the tank and had a welding shop fix it for me.
I had another one that was cross threaded and that one never stopped leaking until I got a drill and drilled it out and rethreaded it to a larger size... I tried the fix it kit with a self threading bolt but that didn't help because the plug was not flat on the nut.
68gmsee is offline   Reply With Quote
Old 11-02-2007, 08:18 PM   #5
tk1251k
tk1251k's Avatar
Smile Re: oil drain plug
Thanks for in info . I picked up another plastic washer from napa but I am going to change oil agin tomorrow and look a little closer at everything. Had oil sender leaking last month tightened it up no more leak. thanks
