11-02-2007, 04:38 PM | #1 |
C10 Club Tennessee
Fuel Tank ????'s
I got my used gas tank out today and took the air drill out getting all of the crap off of it before I hit it with the black chassis paint. I was just wondering what are the other three outlets coming out of the gas tank for??? Obviously the big one is for fuel to enter, but was just wondering what all the other crap was for.
I know it's a stupid question that I should know, but I don't so help please
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
11-02-2007, 05:55 PM | #2 |
Re: Fuel Tank ????'s
Vents that connect to a tube on the driver's side neer the fender well inside the bed, should be a metal tube standing vertical..don't have a pic handy, maybe someone else does.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
11-02-2007, 07:50 PM | #3 | |
Used Register
The large is obviously the filler, the medium is the filler vent, the two at the top front corners are vents and the one on the sender is the fuel supply. Herb BTW - my toes are toward the front, so the back is at the top of the shot. Last edited by herb101; 11-02-2007 at 07:51 PM. Reason: clarifying |
11-02-2007, 11:42 PM | #4 |
C10 Club Tennessee
So, do I even need these other lines??? Obviously need the fuel line but do I need the other three. If so, where to they go? I have a 88-98 fuel door and tube.
11-03-2007, 12:08 AM | #5 |
Used Register
http://67-72chevytrucks.com/vboard/s...=212828&page=2
Post 31 shows the medium size hose and its route to the filler neck. The other two connect to metal lines that run parallel with the bumper on the driver's side rear. My lines are rusted through there, so I don't yet know where they finally wind up. I would guess a charcoal canister somewhere. You'll need some kind of vent to be able to fill the tank, as the air has to escape to let the fuel in. Herb |
11-03-2007, 02:29 AM | #6 |
USMC
you need to vent the tank to keep from building pressure. The only one you need to run to the front is the fuel line to the pump. the other 2 for emissions testing i guess
don't know the official reason they are there but i know you don't need them to run up the frame to make the truck work. so no and yes you don't really need it but you do need to vent it. I would the vent up near the filler hole and vent it there. just to keep it out of harms way.
Semper Fi |
11-03-2007, 09:42 AM | #7 |
C10 Club Tennessee
Thanks for the link. So in essence I just cap the two lines that I've circled from your pic, correct???
11-03-2007, 05:21 PM | #8 |
computer illiterate
if you cap those 2 lines it will fill slower
72 2wd blazer 72 swb 4x4 |
11-03-2007, 07:09 PM | #9 |
can u use one of the two for a return line for fuel injection? if need b?
11-03-2007, 10:12 PM | #10 |
C10 Club Tennessee
So, just leave them alone without hoses????
11-03-2007, 11:13 PM | #11 |
Back in the sticks
The tank on my 69 doesn't have anything hooked to those. Just a little length of hose on the left side for venting purposes. So yes, you can leave them alone and it should be fine. On my 71, I ran the return into the left side for the fuel injection and capped all the others off. It does fill a little slow, but still works fine.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
11-04-2007, 05:08 PM | #12 |
Both of those on my tank go to a small round cylandar next to the fuel filler; behind a square box cover. Then there is also a third line from that cylandar runs all the way to the front of the truck; but isn't connected to anything?
Just an option? |
11-04-2007, 08:40 PM | #13 |
Back in the sticks
It went to the charcoal canister for emissions. My 69 doesn't even have it and I removed it from the 71. If you don't have emissions testing where you live, don't worry about it.
