65 - Chevy C10
removing column shifter knob
I wanted to put on a new column shifter and blinker knob. I was thinking that they unscrewed off but instead, they just keep spinning. Any idea how to get them off?
Re: removing column shifter knob
column knob pulls straight off - not easy
don't know about blinky.
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
65 - Chevy C10
are you sure? I pulled pretty hard on that bad boy!
turn signal should be threaded, the shift knob I cut off. I used a dremel then split it.
65 - Chevy C10
OK.. so you cut it off and then threaded it? What did you put on afterward? I have a little lathe here at work now, And I wanted to fab something up from some scrap aluminum we have.
sorry I was wrong about the turn sig arm. I bought the billet kit from the truck shop. I have a 70's van column. the turn sig is probably pressed on cause the kit comes with a new arm and knob. The replacement shift knob is just held on with a allen screw through the side.
