11-02-2007, 07:52 PM | #1 |
Camaro Club
I want it low..but i wanna keep drums...
is there any way to lower the front of a drum brake truck more than just the two inch coils. It seems like all of the drop spindles made are for disc breaks. I would like to do an axle flip in the back but that means i'm gonna have to get that front end down pretty low. Any info or how to pics would be greatly appreciated. THANKS
11-02-2007, 08:12 PM | #2 |
Official Site Guitar Shredder
Re: I want it low..but i wanna keep drums...
i have drums all the way around this isnt the best picture but i have three inch coils in the front and 5 in the back....... i ran a tall tire in this pic i think the fronts were 225/75 15s and he rear are 235/75s 15s.. i since changed the fronts to 195/65 15s sits very low in the front now.....? hope this helps.........tony.
11-02-2007, 08:17 PM | #3 |
Camaro Club
bad6772
thanks for the info i like the stance of your truck. What brand are your coils? Also does anyone know if i do a flip kit in the rear and 3 inch coils in the front if my truck would be level |
11-02-2007, 08:44 PM | #4 |
no problem... it should be close to level maybe the front just a little lower... you have to ask G.M.C Paul what brand they are ? i got them from him....? but most if not all site venders carry them. here is a couple pics of my 72 pre< this fall> frame off... i was running 3 inch springs in the front and a D.J.M flip kit but it should give you an idea of how the rear should set.hope this helps....also the last pic is about 3 years old with a late model bed on it< now changed to correct bed.> the tires on it are 355/45/17s in the rear and 335/45/17s in the front
11-02-2007, 09:43 PM | #5 |
3" coil & flipped rear, 4 wheel drums...
11-02-2007, 09:52 PM | #6 |
BlahBlahBlah
You can get dropped arms. I think they lower it about 2.5'' If you want it even lower you can used dropped coils also.
11-02-2007, 10:11 PM | #7 |
hmmm, that would have the same basic effect as drop spindles wouldnt it? Nice!
11-02-2007, 10:22 PM | #8 |
Fabricate till you "puke"
You could body drop it 3", but thats a load of work.....L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
11-02-2007, 10:35 PM | #9 |
no its not i body dropped mine in two days
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
11-02-2007, 11:32 PM | #10 |
72 Chevelle Club
Flipped the rear , cut the coils , cut and lowered the spring pockets in the lower controll arms . Cut and welded untill I got it as low as I wanted . Still 4 wheel drums and 6 lugs!!!Oh yeah first i converted it to leaf springs in the rear!!!
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
11-03-2007, 06:39 AM | #11 |
Camaro Club
I'm guessing that all 1/2 ton leaf spring packs are the same but looking at mine its probably 2 1/2 inches thick and the axle tubes are probably 3 so will i get about 6 inches lower in the rear. And can i just put a bolt in notch in it for that.
Corn... Your truck is perfect. Thats the exact look i'm going for only i decided to go with gloss black. |
11-03-2007, 11:53 AM | #12 |
cut coil front (1 ring), flipped rear, & adjusted the spring hanger height. Roughly a 3/5 drop, + 1 1/2" body drop http://community.webshots.com/user/hotrodhorn L
11-03-2007, 07:12 PM | #13 |
I havent notched mine yet & it has never touched anywhere, but I dont haul much with it. Ive got a piece of 6" that I plan on making a set out of...
11-03-2007, 08:25 PM | #14 |
My longhorn isnt notched either, runs about 2 1/2" clearance tween the frame & axle. Its never hit , but the traction bars are set up pretty close. L
11-03-2007, 09:11 PM | #15 |
Camaro Club
Just by looking at my truck it looks as though i will need a small c-notch. Also what do i do about my rear shocks? Just get shorter ones or what
11-05-2007, 10:04 PM | #16 |
Camaro Club
TTT. does anyone have anymore important info i need before i attempt this. I'm getting some spring mounts for the axle from summit racing for $12.00 and my step dad is getting me a piece of 5 inch pipe for free from his work for the c notch. Is there anything else i need other than new U-bolts and my front coils or do i have it all under control?
11-05-2007, 10:24 PM | #17 |
My flip kit has the centering pin offset to compensate for pinion angle & also it centers the wheels back into the wheel well. Not sure rewelding pads back on would fix any of that...
11-06-2007, 07:18 AM | #18 |
Camaro Club
corn...
Thanks for letting me know that before i ruined my truck. I didnt think about it moving the axle. What company did you get your flip kit from. Maybe i'll just buy one from a vendor |
