11-02-2007, 09:29 PM | #1 |
Rear help
there is a metal tag on one of my rear's bolts. It is stamped 4110 and 4 10 does this tell me the ratio?
11-02-2007, 10:00 PM | #2 |
Re: Rear help
Bump...I'd like to know as well, just never got around to asking.
72 C10 lwb fleetside -stock 350/350 combo |
11-02-2007, 10:39 PM | #3 |
Re: Rear help
im not positive but i think that means 41 teeth on the ring and 10 on the pinion 41 devided by 10 would = 4.10 ratio you might be lucky jack it up spin the drive shaft 4 turns and see if the wheels turn 10 full rounds
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
11-02-2007, 11:40 PM | #4 |
Re: Rear help
thanks
11-03-2007, 04:44 AM | #5 |
Re: Rear help
I know a lot of people like to use the "turn the drive shaft and count the revolutions" technique. I would suggest just pulling the cover, if is not an eaton, and count the teeth on the ring gear and pinion. It takes a litlte more effort but I bet you are due for a fluid change anyway, and then you will know for sure. divide the two teeth counts and that is your ratio.
11-03-2007, 07:17 AM | #6 |
Re: Rear help
Yes,those metal tags are the axle I.D.
11-03-2007, 08:11 AM | #7 |
Re: Rear help
if your gonna pull the cover just look for the stamp on the edge of the ring gear should look like this 41:10
11-03-2007, 08:15 PM | #8 |
Re: Rear help
I have a c/20 frame with the rear. I was thinking about holding onto the rear just in case some day i may need it......with the 4:10 is it anything special that I should save? I don't know too much about rear gear raito. I'M NOT looking to sell anything just saving parts I may need someday......I have a c/10 and a k/10 so i'm not looking to use this right now
