What do ya'll think?
I took some measurements for wheels/tires and come up with this. These are rough measurements but it's pretty close. It makes sense though because I had a wheel on there a while back that had a 6" back spacing and the rim was about 2" away from the outside of the leaf spring. I'm running a Ford 9" rear end so that's why it more narrow. Sorry for my quick drawing that might not be exactly to scale but you get the idea. From this, if I wanted to run a 20" x 14" wide wheel I'd need a 6" back spacing. I'd imagine that would need to be custom built. And that doesn't leave me much room for tire buldge or at least as much as I think I want. I want a good amount of tire back there (no low pros) with about a 31" tall diameter tire. So am I limited to a 12" wide wheel or could I get away with a 14" wide wheel and still have room for some tire buldge (section width)?
My 84 C10 build...
http://67-72chevytrucks.com/vboard/s...d.php?t=216158 Last edited by SulphurDave; 11-03-2007 at 01:03 AM. |
a fool with no money
Re: What do ya'll think?
If I looked at that right, you're only leaving 1" between the rim and the fender lip. you're wanting to run a tire with a 5"-5.5" sidewall height (20" rim w/ 31" tire). You didn't mention the TIRE width, but I assume it will be a little wider than the rim to look right. I think that the first turn you take at speed, you're going to shred the sidewall of a very expensive tire. I would go with a 12" rim and a 5" backspacing. just an opinion from a guy who spent hours and hours measuring everything several times in order to stuff as much meat under there as I could
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ |
Originally I was gonna go with a 15x12 with a 14.5" section width and 31" tall diameter drag radial back when I was going for more of a pro street setup. I wanted Weld ProStars but they don't make a 5x5 bolt pattern anymore. I have 5x4.5 on the rear though. Plus now I wouldn't mind going with a more stylish pro touring setup with 20x? deep dish wheel on the rear.
My 84 C10 build...
http://67-72chevytrucks.com/vboard/s...d.php?t=216158 |
I just bought some older used Budniks off Ebay, 17 x 8.5" front and 17 x 11" rear with (respectively) 245/45/17 and 335/35/17 Michelin rubber. The rear rims have a 3.5" backspacing as the previous owner had a F. 9" rear end too. As you can see from the first pic, just so you have more of an idea of what you're looking at, they looked just right with the amount of lowering he had.
He now has a newer style 20" rim and tires. (see pic 2-4) I dunno what they are or have any specs for ya, but i know they are available. Most bigger companies like Budnik, Billet specialties, Colorado Customs ect, offer 20 by 12 or 14" rims with custom backspacing, for ummmm a special price lol. I could ask more info from him if you want, or maybe could set you up to contact him if you need more info? Hope this helps some.
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough! ![]() |
I dunno if you have seen this truck, and again i don't know the spec's on it other than it has DEEP dish 20's or 22's in the rear. I know you also said you didn't want lo pro's but this is just to give you an idea of what yours could look like, hehe. Something like these wheels and tires would look tight on your truck! imo.
Happy to be here
![]() Join Date: Mar 2000
Those look like Billet Specialties wheels that appear to have been custom made.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-05-2007 at 12:26 AM. |
i don't think they are, they don't even look close, are you drinkin again Ken, lol, Kidding!
i like those tho!
See I could do something like this but with a little bit more tire. Yea I'd like to chat with this guy about the wheels. Is he on this board? Thanks for all these pics. I think I'm sold on doing this.
My 84 C10 build...
See I'd like a little bit more tire like this. It has some good sidewall, good tread pattern, aggressive and doesn't look too much like low pros to me.
My 84 C10 build...
Mickey Thompsons.
#12 | |
[IMG] ![]()
My 84 C10 build...
#13 |
see if this helps
http://www.dakota-truck.net/TIRECALC/tirecalc.html http://www.discounttire.com/dtcs/infoTireMath.dos Last edited by jokersbowtie; 11-12-2007 at 10:40 AM. |
#14 |
I have no time for this
I would love to see more pics of the whole truck with the Mickeys on it.
1986 Chevy short box ( PROJECT ) 1994 Chevy Blazer lifted 6" 2009 Gmc 2500 HD 1999 Hugger orange Camaro SS 2007 BMW X5 Sport Last edited by trixter99; 11-12-2007 at 11:21 AM. |
#15 |
Well I don't have any helpful input on tires, but I had to show your post to my significant other. She gives me a hard time about being anal and researching and coming up with measurements and plans and sketches like that, even been known to use AutoCAD for some small silly project.
Anyway, was good to say "See! I's not just me! There's other people out there in the world that do things that way too!"
Paul 1984 Chevy C-10 *LWB/305* |
#16 |
WOW what size were those Mickeys, they are smokin
#17 | |
My 84 C10 build...
#18 |
i just bought a pair of those mickeys for my project truck. i have some 29x18x20. they are sweet they are getting mounted on some boyd wheels junk yard dogs in a 20x15 with a 4" offset. i too have a very narrowed 9" rear
coys makes a sweet 20x14 and boyd has a lot of styles in a 20x15 check them out but they are about $1000 each |
#19 | |
My 84 C10 build...
http://67-72chevytrucks.com/vboard/s...d.php?t=216158 Last edited by SulphurDave; 11-13-2007 at 10:20 PM. |
#20 |
Until Seventy Times Seven
SulphurDave,
You may be able to squeeze a 14" wide wheel under the rears. Do you have a specific tire (Brand/Model) you want to run. You mentioned a 31" tall tire on a 20" wheel for some sidewall meat. Looking at the tire specs for the Mickey Thompsons Sportsmans S/R with a 31" diameter, they offer a 31X16R20LT with a section width of 15.7". You'll have 'bout 1.3" of overall clearance. Running a 20x14's with about a 7.25" BS would give you about a 1" clearance between the sidewall and the inner fender lip, but only 'bout a 0.25" clearance between the sidewall and the leaf spring. If you run it with a 7" BS, you could gain more clearance from the leaf spring, then 'roll the inner fender lip to maintain a 1" clearance from the fender lip. Mickey Thompson also offers a 29x15R20LT that has a section width of 14.7" abiet only 29" in diameter. You could run this tire on a 20x14 wheel. I imagine this profile would look closer to the pic that you posted running the M/Ts. Running this setup with a 6.75" BS would give you at least an inch clearance on either side. Do you plan to do a four bar sometime down the road?
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
#21 | |
My 84 C10 build...
#22 |
Just talked to Centerline and they can build some 20x12 wheels for the rear with a 5.5" backspacing in a 5x4.5 for $390ea. The front might not work I don't think. I would want 20x8.5 in a 5x5 in the front which they have and would sell for $345ea but they can only do 5"-6" back spacing. Shouldn't the front be like 3 3/8" backspacing or something like that? That's only $1590 for 20x12 & 20x8.5 shipped to my door he said. Oh and the only wheels he can do this to are the offroad wheels. The billet style wheels only come 9.5" wide and 15" wide nothing in between. I would wanna get the Wildcats. He said I would be the first one to get 20x12 in that wheel but he has done other styles in 20x12 in those series wheels. The 20x8.5 are 33lbs and the 20x12 are 40lbs. That seems heavy but I've never compared.
This is the wheel in a smaller diameter. ![]() But once you stretch the spokes going to a larger diameter I think they would resemble more along the lines of the Foose 500 wheel or something close. ![]()
My 84 C10 build...
http://67-72chevytrucks.com/vboard/s...d.php?t=216158 Last edited by SulphurDave; 11-15-2007 at 04:10 PM. |
#23 |
73 ~ 87's w/stock GM manufactured front suspension set-ups (meaning no MII's, Dropmembers, narrowed a-arms or clips etc) would use from 4 ~ 5.75" BS on a 8.5" wheel. I have 5.25" w/8's & I could get away w/a little less w/o worrying about rubbing the fender.
Somewhere around 4.5 ~ 5" BS should work well for you.
#24 | |
My 84 C10 build...
#25 | |
I don't care for the hanging-out in the open or flush-fit options because I like mine LOW. But, you can also tuck them in too far as well. I really dis-like over-narrowed track widths. You just need to figure out what's most appealing for you.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-15-2007 at 06:28 PM. |
