Old 11-03-2007, 04:32 AM   #1
ridin98ci
ridin98ci's Avatar
weather stripping
I need some pointers on getting my new weather stripping to stay on.
I have cleaned the surfaces and degreased applied the yellow snot from 3M and waited for it to tack then install the rubber and the s**t dont stick......HELP ME
Im gonna slam a 3/4 ton....I may be nuts!!!
ridin98ci is offline   Reply With Quote
Old 11-03-2007, 04:53 AM   #2
wibilly
wibilly's Avatar
Re: weather stripping
did you put it on both surfaces? i used some cloths pins to help hold it for a little while and lots of rubbing and squizing while instaling
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 11-03-2007, 07:19 AM   #3
70c10
67-72 Addict!
70c10's Avatar
The clothes pin trick works great!. I am planning to use the mid 80's S-10 truck/Blazer weatherstripping because it's better quality and it's pressed on with NO glue!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-03-2007, 08:07 AM   #4
Yeller68
Active Member
Yeller68's Avatar
I used the blue painters tape, since I didn't have any clothes pins. That worked good also.
Yeller68 is offline   Reply With Quote
Old 11-03-2007, 09:35 AM   #5
ridin98ci
ridin98ci's Avatar
how do u get it on both surfaces, thats my problem....I think. if u put it on the inside wont it seal the stripping shut?
Thats a great idea about the S-10 stuff.......is it long enough?
Old 11-03-2007, 10:12 AM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I got some door rubber from a round body S-10 single cab (don't know the year) & put it on my black truck
It's about 3" too short, but it could be that I didn't stretch it enough when I put it on (I was on the phone & holding a flashlight)
It seals really tight, so I may have to adjust my door a bit so I don't have to slam it shut
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 11-03-2007, 10:37 AM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
Get the black 3M weatherstripping stuff. Works well. Apply a thin bead to both sides of the door jam. Also, apply a thin bead to the inside of both sides of the weatherstripping. I'd only do a couple feet at a time. Let it dry for a couple minutes so it's tacky. That's when you need to install it. If you install it right after you apply it it's not going to stick and just slide/fall off.
I installed used S-10 stuff of a 89 or something like that. It's too thick and I don't like it. My doors are aligned well and over a year later I still have to slam the doors to close them (and push on them a little when I lock them.)
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-03-2007, 11:05 AM   #8
ridin98ci
ridin98ci's Avatar
Thanks for the tips....I wish I would have known there was black 3M goo cuz now my rubber has some nasty green/yellow marks.
I wish this stuff was eaiser to use.....some one should design a push on that fits our trucks
