Old 11-03-2007, 08:02 PM   #1
rogergodding
rogergodding's Avatar
can bad gas/nasty tank cause valve problems?
my truck hasn't been driven much the past year and the tank has been bad for a while. I just bolted up a new edlebrock 600 and am running gas from the new tank to it. the idle is rough. timing has not been adjusted. there is a slight tick, I've needed to do a valve adjustment for a while. I'm just wondering if there is some damage to my valvetrain..... any thoughts appreciated.....
rg
rogergodding is offline   Reply With Quote
Old 11-03-2007, 08:13 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: can bad gas/nasty tank cause valve problems?
Originally Posted by rogergodding View Post
my truck hasn't been driven much the past year and the tank has been bad for a while. I just bolted up a new edlebrock 600 and am running gas from the new tank to it...
Can you explain re: tank has been bad for a while? Does this mean that you replaced the bad tank and now have a new tank with fresh gas?
Bad gas makes a difference in the way it runs but you'd have to run some real bad gas for a long time before it would do damage to your valve train.
I imagine you'd get pretty tired of rough idle, sputtering and misfiring fairly quickly...
68gmsee is offline   Reply With Quote
Old 11-03-2007, 08:20 PM   #3
rogergodding
the tank had that smell, rust on the inside of the gas cap etc.
it just recently started running rough, (I'd run it every day or so), it got bad enough that it wouldn't idle and would backfire.... so I changed the carb.....
my new tank has fresh gas
Old 11-03-2007, 08:39 PM   #4
cdowns
cdowns's Avatar
i'd look more at a timeing chain or distributor points problem
Old 11-03-2007, 08:50 PM   #5
rogergodding
accell blueprint hei.... entire engine has only 2500 miles on it....
Old 11-03-2007, 09:25 PM   #6
68gmsee
Active Member
68gmsee's Avatar
I'm still missing something. You mentioned that it started acting up, wouldn't idle and it would backfire and then you changed the carb.
Question I have is did you run some bad gas through before you changed the tank?
Also, did it run okay after you changed the carb? Could be the carb may also have a problem?
I'd check for vacuum leaks first. Sometimes you can't see them, but, old rubber will crack and can sure screw you up.
Then go down the list. Check timing, to make sure its okay.
Spark plugs to insure they didn't get messed up by the bad gas.
Loose wires in ignition.
Fuel filters to make sure they're not clogged up.
Old 11-03-2007, 09:26 PM   #7
OhioDan
OhioDan's Avatar
Question Re: can bad gas/nasty tank cause valve problems?
Did ya change fuel filters when ya installed the new tank? Might help?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 11-03-2007, 09:33 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Forgot to add... If it's backfiring through the exhaust, that's an indication of unburned gas igniting as it's going into the hot exhaust. A rich adjustment may cause this as well as plugs, wires, etc..
I've had bad valves, but for the most part, I've had them sputter and miss occasionaly. Usually get better at higher rpms. I guess if they are bad enough they can backfire through the carb and exhaust also.
Only other thing that comes to mind is a bent push rod or valve caused by the backfiring...
Old 11-03-2007, 09:36 PM   #9
rogergodding
no bad gas was run through the new carb
since new carb was installed, it will now idle, but is rough
only vacuum leak would be on the dist. advance hose or the pcv, the brake booster vac is plugged currently
new inline filter
Old 11-03-2007, 09:38 PM   #10
rogergodding
with the old carb it was backfiring really bad through the exhaust.... no backfire now just a rough idle and I guess I forgot to mention, that roughness continues through the entire rpm range.....
Old 11-03-2007, 11:00 PM   #11
rogergodding
thanks for all the feedback. will be checking for leaks and inspect the wires and maybe do that valve adjustment tomorrow.......
Old 11-04-2007, 10:21 AM   #12
68gmsee
Active Member
68gmsee's Avatar
If running rough is missing and/or sputtering out the exhaust, it may be caused by carb adjustments, bad valves, ignition and or electrical problems.
Some years ago I bought a rebuilt carb from a local auto parts store. It ran rough the same way and I took it back for a replacement. The replacement didn't give me any problems.
Let us know what you find.
Old 11-04-2007, 03:48 PM   #13
rogergodding
well it seems as if the problem was these little thingys I've never had plugs this bad.......
Old 11-04-2007, 06:23 PM   #14
68gmsee
Active Member
68gmsee's Avatar
Man, them's some nasty looking plugs... Hope that fixes your problem.
Thanks for update.
Old 11-04-2007, 06:38 PM   #15
rogergodding
yeah that fixed it! now to actually install the new gas tank!
Old 11-04-2007, 07:10 PM   #16
68gmsee
Active Member
68gmsee's Avatar
Okay, now you got my interest... That tank looks like the one on my old '96Tahoe. What is it out of and how are you going to install it?
I've got a 68 GMC but I'm staying with the stock location on it. However, I'm seriously thinking of removing the one on my 69 chevy and getting a rear mounted one.
Old 11-04-2007, 07:41 PM   #17
rogergodding
I just got that from LMC, it is going under the bed as soon as I have my exhaust altered and the remnants of an old "donkey dick" hitch removed......
