11-03-2007, 09:06 PM | #1 |
clutch adjustment
Need to stop the throwout bearing from spinning all the time, one way I can do this is just to hook my foot under the clutch pedal and pull the pedal up a bit and it will stop.
Is there any way to fix this, perhaps get a stronger spring under the dash that can pull the pedal all the way back to the top? |
11-04-2007, 09:24 AM | #2 |
On a budget like Fred Sanford
Re: clutch adjustment
You should have a return spring going from the clutch fork to somewhere on the frame that keeps the bearing off the pressure plate when the clutch is engaged.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
11-04-2007, 10:06 AM | #3 |
Robert Olson Transport
its a heavy spring under the dash that brings the clutch pedal to its normal position when not engaged. the springs can rot and get weak.. they are available aftermarket from HELP i think thats where i got mine on the 76 i had its been a couple of years
11-04-2007, 11:30 AM | #4 |
This may help with adjustment
Disconnect the return spring at the clutch fork. Rotate the clutch lever and shaft assembly until the clutch pedal is firmly against the rubber bumper on the brake pedal bracket. Push the outer end of the clutch fork rearward until the throwout bearing lightly contacts the pressure plate levers. Loosen the locknut and adjust the rod length so that the swivel slips freely into the gauge hole. Increase the rod length until all lash is removed. Remove the swivel from the gauge hole. Insert the swivel in the lower hole in the lever. Install two washers and the cotter pin. Tighten the locknut, being careful not to change the rod length. Reinstall the spring and check the pedal free travel. It should be 1 3⁄8 –1 5⁄8 in. - Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
11-04-2007, 03:37 PM | #5 |
Thanks for the explanation, I will definitely check the adjustment again but I think I've got it set properly but it's good to know how to do it properly! I don't think there's enough adjustment to bring the pedal right back to the top though. I think the spring under the dash on the pedal itself has just become very weak.
I'll go check the HELP section at the parts store right now |
