![]() Join Date: May 2007
dash question
What would be en voled to putting a 1960 dash in a 1966 truck
Thanks James
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Re: dash question
The entire dash is actually welded into the truck, you have to cut it off with the windshield out if I remember correctly.
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
and a few others
Re: dash question
And, the 60 has the wrap-around windsheild, the 66 has the semi-straight, so the dashes are even shaped completely different.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Justified!
Re: dash question
Do you mean just the gauge panel? Or the entire dash?
Do the 60's even have a dash panel? or are the gauges in metal? hmmmmmm
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny ![]() |
Re: dash question
ive seen a few trucks with a 59 - 60 impala dash
Re: dash question
I just cut a ac dash out of a 72 blazer and it was pretty easy.I want to put a 66 on a 79 4x4 frame but I really like the early 60 dash,just thought someone might have tried it already.
