I did some searching on this site and could not find it. I wanted to know if they ever made a swb coil spring 4x4?
Re: Coil Spring 4x4 swb?
no chevy or gm truck came that way.
Earl 68 2500 4x4 GMC Burb Last edited by earl87gta; 11-04-2007 at 12:38 PM. |
I'm a poor spectator
I've seen a 2wd converted to 4wd with coils all the way around. I gotta say it looked pretty good and it probably rode pretty nice as well.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
#5 | |
K5Camper
![]() Join Date: Mar 2004
Back on subject, coils on 4wd solid axle trucks. People have done it, but it will require a complete 3,4 or 5 link arrangement to locate the axle as the coil would only support the wieght. Leaf springs perform both functions of supporting the wieght and locating the axle. So if you take the leafs away, you got to put something back to position the axle/connect it to the truck. Changing over to coils is not an easy operation and requires you know some stuff on suspension design. Until ORD comes public with their coil-over 4 link conversion, nobody sells a bolt on kit to ditch the leafs on a solid axle gm truck. If you want an example of what it takes to link up a solid axle trucks, there was a thread in the suspesion section of this site that did just that. He linked up the front and rear of a 70 or 71 K10 so he could run airbags front and rear. He wasn't putting bags on to drop it, just to give a really soft ride and give some adjustment up and with loads. Took a lot of fab work to link it up. I'd post the link, but couldn't find it with the search function here...
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
here is the air bag thread http://67-72chevytrucks.com/vboard/s...d.php?t=200909 you could also look at a doge truck they were all coils up front from I think 93 until now.
Earl 68 2500 4x4 GMC Burb |
