Old 11-04-2007, 04:41 PM   #1
Blue71LWB
Blue71LWB's Avatar
Question What bench seat will give me more room?
I need to get a new seat , but I do not like the feel of the stock seat in my 71.
Is there a bench seat out of another year model or another make Ford/Dodge that will give more leg room. I'm 6'6" 260lbs and the stock seat is a little tight for my liking.
Thanks,
Zac
Working on my first 1,000 post.
I'm sure I'll get there before this project is over .
Blue71LWB is offline   Reply With Quote
Old 11-04-2007, 04:42 PM   #2
cdowns
cdowns's Avatar
Re: What bench seat will give me more room?
the one in the park
Old 11-04-2007, 04:47 PM   #3
Scott68-93-97
Scott68-93-97's Avatar
Im 6'1" and I have a 89 chevy bench seat in my 68 and Ive got plenty of room with this setup
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 11-04-2007, 05:09 PM   #4
Blue71LWB
Blue71LWB's Avatar
Scott.
I looked at your build pics and your seat does look like it will give a little more room. Thanks for the help
Old 11-04-2007, 05:20 PM   #5
Yeller68
Active Member
Yeller68's Avatar
Originally Posted by cdowns View Post
the one in the park
I thought the same thing.
Zac, you might also want to look in the faq, and try the steering column shortening trick. I haven't done it myself, but have thought about it. Here's the link
http://67-72chevytrucks.com/vboard/s...d.php?t=191143
Yeller68 is offline   Reply With Quote
Old 11-04-2007, 05:30 PM   #6
cstanley
cstanley's Avatar
i always wondered if you could build in a custom seat where the gas tank was - in other words, the seat back would be lower and would "flush-out" with the sheet metal below the rear window. I don't think it would be too low, and would still give plenty of padding space, and would give TONS of legroom...
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 11-04-2007, 07:02 PM   #7
67shortie
Green club
67shortie's Avatar
I am in the same boat as you are, 6-9 and 290 but I manage. Must be all of those years of squeezing into everyting but caddies
At least the trucks have headroom
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 11-05-2007, 09:31 PM   #8
Scott68-93-97
My seat still has an inch or two before hitting the tank too
Old 11-05-2007, 10:54 PM   #9
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
i found that removing the tracks on the bottom of the seat, and setting it on the floor works well. i'm 6'3" 260 and have no complaints.
Just got done putting about 300 miles on her today, and have not aches to complain about.
my 2 cents
IvelDesigns is offline   Reply With Quote
Old 11-05-2007, 11:11 PM   #10
Rokcrln
Rokcrln's Avatar
Well I am only 6-0" and 205lbs but still need a bit more leg room. I have a bad back and my knees kill me if they are in a crampted position for to long. I have done the column shortening and that is a big help for your arms being very comfy while driving but my knees still get it. I have put several thousand miles in the last few months and it has gotten to be too much. My tank is already in the frame so I am to looking for a new seat.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-06-2007, 04:19 AM   #11
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
The 73-87 seats are about 3 inches lower than ours. The later models have a raised floor so the mounts are shorter. I'm only 5'10 so it didn't work for me My wife is 5'even and she couldn't see over the dash. But for a tall guy it may be perfect.
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 11-06-2007, 05:53 AM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'm running a 73-87 bench on my stock 72 tracks. It's a good bit lower. I'm 6'4" and 240 pounds. Fine for me.
Old 11-06-2007, 07:52 AM   #13
OJOE
Crew Cut
OJOE's Avatar
from all the seats i have seen this works and looks the best
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 06-27-2008, 06:39 PM   #14
Ford Assassin
Ford Assassin's Avatar
Does anyone have a pic of a '73-'87 bench seat in a '67-'72 cab?
Thanks!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 06-27-2008, 07:06 PM   #15
68gmsee
Active Member
68gmsee's Avatar
I took the back seat of an 86 crew cab. The front is almost identical but the back seat is tiltable. (excuse the unfinished truck.)
I didn't use the mounting brackets that came with, I used the bottom brackets from my old seat. I did have to drill a hole to bolt it to the seat. I also had to form the back bracket.
68gmsee is offline   Reply With Quote
Old 06-27-2008, 07:10 PM   #16
Psycho71
Psycho71's Avatar
Lower huh? I went the other way. I grabbed a pair of buckets out of a Plymouth Voyager mini van that sit a few inches taller, and they gave me all of the legroom I need. I'm 6'3", but only weigh 180lbs. The steering wheel is kinda close to the legs now, with no tilt, and my head is kinda close to the roof, but I'm comfy as can be. The only thing I really do not like is that they are high back buckets, and the headrest is almost to the top of the rear window. Looks a little odd from behind, but comfort rates higher for me.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 06-27-2008, 07:13 PM   #17
Ol'Rover
Project: years too late.
Ol'Rover's Avatar
i have an 89 or so Ford seat, i got lots o room. but im only 5'11 185lb. soo...
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here.
Ol'Rover is offline   Reply With Quote
Old 06-27-2008, 07:16 PM   #18
jhow66
jhow66's Avatar
Uh Blue71', check to see if the seat at the dinner table moves back further. wink wink
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-27-2008, 08:36 PM   #19
cparman
sharp as a marble
I am a long legged 6'1". I went to Home Depot, and bought a piece of 1" square tubing, and made spacers for my stock seat 1969. MAN did it make nice difference. It raised the seat 1", and made a very nice change
cparman is offline   Reply With Quote
Old 06-27-2008, 09:29 PM   #20
Sammy
Since our stock seats are so thick I think if your looking for leg room I would look for a thinner seat but I wonder how comfortable they would be bottom cushion on your tail bone. If your having gut interferance tilt would be they way to gain room.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 06-28-2008, 06:31 AM   #21
caminokid
Chevy nut
caminokid's Avatar
I had a seat out of a 77 Chevy truck in my old 69. It sat lower. It also sat at the sheet metal under the back window. I also used the original tank. It was easier getting in and out of the truck.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 06-28-2008, 10:44 AM   #22
thirdstreettito
Resident of Here
thirdstreettito's Avatar
I was gonna ask the same question cause I'm 6'3" 285lbs, I'm a big boy. And I want to fit in the truck comfortably, I was also thinking about getting some corbeau seats.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 06-29-2008, 11:35 AM   #23
kelsfine69
18 Till I Die
kelsfine69's Avatar
I have read on here that a 2nd row seat out of a Classic 2000-06 suburban or Tahoe works well. Now that The new bodys are out has anyone tried the newer 2nd row seats(07-08)?
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 06-29-2008, 02:22 PM   #24
caminokid
Chevy nut
caminokid's Avatar
This is the old 69...R.I.P.
I used the 77 brackets. Didnt have the original seat to the 69.
Old 01-11-2009, 11:51 PM   #25
Ford Assassin
How hard was it to switch out the tracks from the older seat to the newer one?
I ask because I have the stock '69 bench and its too tall and stiff for my liking. I have a decent shape bench from a '73-'87 and it a bit too low for my shorty wife. I was hoping the tracks from the '69 seat would give a nice happy medium between the two heights.
Thanks.
Cable
