Old 11-04-2007, 05:06 PM   #1
blazntn
C4 Install? for Nathan Porter
Nathan I am installing the C4 rear. The guy doing my fabrication is thinking about building a ladder bar type setup. I was wondering if you think this will work without binding. He is planning on mounting the bags on the top bar.
blazntn is offline   Reply With Quote
Old 11-04-2007, 10:02 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: C4 Install? for Nathan Porter
I would not recommend using a ladder bar design... it would definitly bind, especially with the factory links and bushings. I saw a similar set-up a while back on a 55-57 truck... he used a ladder bar style link, but changed ALL the factory links and used heims in place of the rubber bushings to help eliminate binding.
I would stick with a four-link design. Why not run the bag off the upper four link bar? It would definitely need some reinforcement, and a nice trussed gusset on the bar, but would do the job.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 11-05-2007, 09:07 AM   #3
blazntn
Thanks, man I was worried about the binding. If you use hiems on just the rearend would that eliminate the bind? Also dont forget about those pics!!
Old 11-07-2007, 07:48 PM   #4
blazntn
hey Nathan, i have talked to several people about installing the C4. Several have said to sell it! Others say the ladder bar wont work. I was just wondering how well you setups work. Are you having binding problems? What are some good ways to mount the bag? I dont want a canti setup like you do. I want to have a stock looking floor.
Old 11-07-2007, 09:27 PM   #5
PBFAB.COM
PBFAB.COM's Avatar
Again... I wouldn't use a ladder bar set-up. On my set-up I have had no issues with bind (if you want to get really technical nearly all suspension link designs will have somesort of bind... small or large and anywhere in between!). I have found the best way to get the necessary travel, spring rate, and ride quality is to run them canti-levered like I do. If you're not wanting to cut the floor up too much you may need to think outside the box a little. I do have another design that keeps it below the frame-rails...but I am not giving that one away yet!
If your not able to meet all the desired criteria you may need to rethink the rear-end.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-08-2007, 07:20 AM   #6
blazntn
well thanks we will work it out.
Old 11-08-2007, 07:36 AM   #7
blazntn
Do the link bars require heims at both ends. Or can you get away with a heim and a rubber end? Can you mount the bag on the bar and use two heims, or will the bar twist? Sorry for all the questions!
Brad
