Old 11-04-2007, 06:38 PM   #1
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Fatmat Sound Deadner???
Any one done the Cab able to tell me if this is enough to Do a Good Job on Cab??
Thanks, Rick
50^ Ft FatMat Auto Sound Deadener
Will This Be Enough?
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 11-04-2007, 06:55 PM   #2
67shortie
Green club
67shortie's Avatar
Re: Fatmat Sound Deadner???
That's what I will be using as well, the 50. In our trucks I can't see using more than 50 unless you do the roof too?
I will be doing this in a couple of weeks, maybe I will post progress pics to see how far 50sf goes in these cabs.
this stuff is quite a bit cheaper than dynamat.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 11-04-2007, 06:58 PM   #3
Mondo
Mondo's Avatar
I've ordered the same a few days ago... hope we're right
Mondo is offline   Reply With Quote
Old 11-04-2007, 10:28 PM   #4
IAFF2407
IAFF2407's Avatar
hey Mondo were you on the I5 two weeks ago sunday heading south from the seattle area?
1972 GMC Sierra
1972 GMC Super Custom Suburban
IAFF2407 is offline   Reply With Quote
Old 11-04-2007, 10:52 PM   #5
crzngmychvy
"1972 C5"
crzngmychvy's Avatar
I put it in my blazer. Here is a link.
My advice is that it is better to have some left over the not enough.
- 72 2wd Blazer ...sold...
2wd Blazer Page
crzngmychvy is offline   Reply With Quote
Old 11-05-2007, 09:54 AM   #6
Shane
Shane's Avatar
I used FatMat and it will require a little more than 50 square feet if you do the inside of the doors and the entire cab. (the rear window-down back wall-across floor-up firewall-behind dash to just under the front windshield).
I purchased the 100 square foot package off ebay only because they didn't offer a 75 sq. ft. package. That would be just about perfect.
Goes on easy with a heat gun / hair dryer. Do yourself a favor and buy some art poster board and make patterns for the goofy shaped areas under the dash. It's kinda difficult to trim the stuff when you laying on your back upside down under that dash.
I'm actually using 2 layers ... 1st layer is FatMat (sound) and then on tope of that I am using the foil backed jute-type padding (for heat/cold). Here's a pic that shows the FatMat on the floor, but also shows the foil backed jute padding on the firewall.
Shane is offline   Reply With Quote
Old 11-05-2007, 10:01 AM   #7
toomanytoyz
Luv the Crewcabs
Shane,
Thanks for the Info & Tip, I was Afraid that the 50 would'nt do it. No Use Doing it if You Don't Do it Right, I will Get the 100................
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 11-05-2007, 11:03 AM   #8
hotrodhomi
hotrodhomi's Avatar
does this stuff work as good as dynomat?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 11-05-2007, 11:17 AM   #9
70cst
70cst's Avatar
Will this also offer heat protection?
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 11-05-2007, 11:28 AM   #10
70cst
70cst's Avatar
http://www.sounddeadenershowdown.com/
Some interesting info.
Old 11-05-2007, 06:44 PM   #11
mnunn454
mnunn454's Avatar
I installed 100 sq feet in mine. (floor, firewall, inside both sides of doors, back of cab). It's not on the road yet. Most noticeable improvement so far is the doors now close with a "thud" rather than a hollow bang.
I chose FATMAT because cost per square foot (it's cheaper than most) and regarding sound deadening, it's comparable to most.
Only drawback to FATMAT is in super hot areas (e.g. summertime southern parking lots with the windows rolled up) the adhesive isn't as good (will come loose) as with the top shelf stuff. Since my truck is either garaged or I'm driving it with the windows down, the temp restriction is a non-issue and the cost per sq ft. (about $1 per sq ft in a 100 sqft roll) becomes the major factor.
Application was real simple. Went well. Took me about 6 or 8 hours in total. The plastic roller that came with the big roll worked fine until it snapped. I ended up using the butt of a screwdriver in order to ensure every inch was pressed firmly against the metal.
Here's a few in-process pics before I laid the final firewall pieces.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 11-05-2007, 07:02 PM   #12
toomanytoyz
Luv the Crewcabs
Thanks to all for Input, The Heat will be a Non Issue for me also. Thanks for all the Tip's on Application. Thanks mnunn454 for the tip on the roller, I will Buy a Wallpaper Seam Roller .............
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 11-05-2007, 07:04 PM   #13
toomanytoyz
Luv the Crewcabs
Shane,
Where did you get the other Type you used on your Truck??
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 11-05-2007, 08:05 PM   #14
67shortie
Green club
67shortie's Avatar
Originally Posted by 70cst View Post
OK, so this guy is saying to go to Lowes or Home Depot and use 'peel and seal' products instead of FATMAT/Dynomat original etc asphalt based products for cost savings. Humm.
The peel and seal products are rated to 158* like the FATMAT.
I don't know, I think a small area test for me is in order.
Old 11-05-2007, 08:27 PM   #15
Mondo
Mondo's Avatar
IAFF2407,
That wasn't me,
I just got a picture of the weinermobile until I take one of my truck... I was with IAFF246, in Bakersfield, until I promoted out... retire next month.
I just did my truck today. I bought the 50ft & some for the doors. Used 1 sheet of the door material to finish the cab (pretty much a 2nd layer over the trans hump).
Shane yours looks awesome! I wish I could of gotten way up the firewall like yours but with Vintage A/C and all the wires mounted there was no way.... pretty much level across, right under the steering column.
The good thing is that the guy before me had it all undercoated so it was real easy to clean and no rust etc... Too bad he didn't do this while he had the cab off and all apart.
Well tomorrow I do the doors. Look forward to hearing the difference.
Old 11-05-2007, 08:41 PM   #16
Shane
Shane's Avatar
Originally Posted by toomanytoyz View Post
Shane,
Thanks, Rick
I picked up 3 rolls (4' x 6') at the NSRA Nationals in Loo-E-ville about 2-3 years ago ... I know LMC carries it and I'm pretty sure some of the vendors here can get you the same stuff. It's actually more of a pain in the butt to do than the FatMat stuff due to having to use the spray adhesive (3M Super 77).
Good Luck and show us pics once you get started.
Old 11-05-2007, 09:07 PM   #17
jfalesi
Junior Member
Man, that's a sweet Blazer. Arroyo Bro's - aren't they the guys Boyd Coddington uses?
jfalesi is offline   Reply With Quote
Old 11-06-2007, 12:53 AM   #18
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Ttt
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 11-06-2007, 12:03 PM   #19
Raven Lunatic
On the Hillbilly Highway
May be a stupid question, but has anyone used spray-in bedliner instead of matting? Something I'm considering...
Does anyone else smell smoke?
1967 GMC 910, rolling frame coming soon!
Raven Lunatic is offline   Reply With Quote
Old 11-06-2007, 05:24 PM   #20
crzngmychvy
"1972 C5"
Thanks about the blazer - About arroyo's, it's a small local shop and not the one from boyds. They do great work though.
2wd Blazer Page
Old 11-06-2007, 07:22 PM   #21
Mondo
Mondo's Avatar
My truck has a black undercoating sprayed in the cab, not as thick as the bedliner stuff. It didn't help deaden sound though and with just the carpet it was a tin can.
I kept my expectations low and am really pleased with the sound deadener. The exhaust, at about 1200rpm, would vibrate everything. Now I hear some outside the cab but inside I can hold a conversation (until the wind noise from the wingvents starts whistling, next project...).
It's kind of a tar substance so I don't think the spray on liner would work for vibration.
My carpet doesn't go up as high as the fatman stuff. I don't think you can paint that aluminum material. Any suggestions?
Old 11-06-2007, 07:39 PM   #22
Frizzle Fry
Frizzle Fry's Avatar
I put several layers of the stuff on my burb roof and didn't notice any difference. If I knock on the non-"peel-n-seal" area and then on the "peel-n-seal" area it's hard to tell the difference.
The stuff isn't easy to get off either. I say don't waste your time. Buy some real sound deadener.
Frizzle Fry is offline   Reply With Quote
Old 11-06-2007, 11:17 PM   #23
ChevyDude
Spray in bedliner inside the cab for sound dampening.....I'd say NO. But under the cab as an undercoating...a big thumbs UP! I just shot a 68' Camaro underbody and wheel wells...came out great. Cab underbody ahs got to be clean....or foget it.
I used DynaMat Xtreme in my 71' but am going to try Second Skin Damplifier Pro on Project OverKill.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 11-07-2007, 01:32 AM   #24
chev74
Addicted to Chevy
chev74's Avatar
i have the do-it-yourself version of rhinolining (Herculiner) on my floor. no help with sound. My truck has lots of road noise and ots of vibrations
chev74 is offline   Reply With Quote
Old 11-07-2007, 07:18 AM   #25
earl87gta
earl87gta's Avatar
Have any of you guys heared of it falling off on a hot day?
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
