Wheels Back to the drawing board!!!
Well I got the Foose wheels I bought off of eBay. Surprise! they do not fit!!! Guy said they where for a 68 with six lug but the center hub is the issue. Wheel does not sit properly on the hub... They are for a late model application. I did secure some rally six lug wheels so I am returning to a stock looking appearance for now. This sucks about the wheels but I like the look of the six lug rally wheels... How do you guys keep the center caps on the wheels???? I have wheels, 4x4 center caps and trim rings...
All Toys: 1971 C10 Fleetside - I needed it! 1970 C10 Stepside - Midlife Crisis 1969 C20 3/4 Longbed - Beast! 1966 Mustang Fastback - Daily Fun 1965 Mustang Fastback - Money pit! |
Re: Wheels Back to the drawing board!!!
You could just get spacers to space the wheel out just enough to clear the hub. Of course u would need to measure for fit and such, but it might work...
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine... 1966 C10 SWB Fleet, 250 I6, three on the tree.... Previously Owned.... 1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4.... 1972 Chevy LWB Fleet 350/350 EXTENDED CAB ALL THE WAY! .._..~...-...._...____ .._..-...______|_|__\____ ..-..~.|_(O)__|_|__|_(O)] |
The factory caps bolt on with 3 self-tapping bolts from the back of the wheel.There are the later `88-up caps that use special lugs and screw-on lug covers to hold them on.Those look real clean.There are two types and I`m not sure if the other type bolts like the earlier ones or clip onto lugs.
I`m not sure how these are held on... ![]()
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-05-2007 at 08:55 AM. |
Thanks for the help!!!
Special-K, they prob used short self tapping screws from the back-side of the wheel into the 'webbing' (thicker areas of plastic) on the back side of those late model caps. Then you can use standard lug nuts vs. the slightly more exspensive 'conversion' lug nuts.
#6 | |
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S Last edited by 72 Cheyenne402; 11-05-2007 at 10:53 AM. |
Thanks Scoti.I think the chrome acorns look alot better,too.
I wondered about machining the center bore.I`d want it riding on the hub center,no spacers.
I bought a set of chrome rally wheels for now! Call it a sign from above....
Freeeeee Mason...
I bought 22" Eagle 026s and had a similar problem. They fit fine in the front, but the back tucked in way too far. When I dropped the truck off the lift, the bed actually rested on the tires. I had to buy 1" adapters/spacers.
Had the hub issue with my ST's... Sent the wheels to the machine shop and for $80.00 the problem was solved.... Ended up spacing them anyways because I wanted them out further...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
