11-04-2007, 11:17 PM | #1 |
"Dually" Noted
Just finished my big block install and am ready to start working on the dually conversion, would like to hear from anyone thats already done one ,or has one and can pass on some pearls of wisdom....I've measued axels from 44" to 59" backing plate to backing plate, any prefs on the width? What is the general gear ratio's on the dually's? And how expensive is it to change the ratio? What about fenders? Have had thoughts about using step side fenders and trim them to fit, or using a late model dually bed, any prefs?
hooberjon@yahoo.com "Life's Been Good To Me So Far" 1941 Chevy PU (new project, right out of the field) 1948 P/U: 350/700r4, Nova Clip,Chevelle rear, air ride suspension, custom door handles, custom firewall, custom dash, buckets and console, visor 1967 C20: 427 Tall Deck, Turbo 400 with Gear Vendors aux tranny, 5th wheel, 3500 bucket seats and console. 1996 Geo Tracker 2x4 1996 Geo Tracker 4x4 |
11-04-2007, 11:26 PM | #2 |
Luv the Crewcabs
Re: "Dually" Noted
You May want To Check This Thread Out, He has Done a Good Job & Goes in Depth on How to Use Stepper Fenders...........
http://67-72chevytrucks.com/vboard/s...d.php?t=254096 Good Luck With Your Project, Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
11-04-2007, 11:35 PM | #3 |
I have a radical idea!
Re: "Dually" Noted
Thanks toomanytoyz! The rearend I'm using is out of a '97 C3500, and it measures 90" from outside to outside. I'll measure from backing plate to backing plate for you tomorrow. I'm running 4.10's in mine, and I am going with a 6.5L Turbo Diesel. Making the fenders was much easier than I thought they would be. Feel free to PM with any questions or concerns about doing them. I bought a set of bigger, wider tires for it today. I'm hoping it will bring the outside of the dual tires closer to the wheelwell. If not, I'm probably going to shave about an inch off of the stepside fenders. I'll keep you posted on that. I'm still also trying to decide if I want to droip the rear or raise the front to even out the stance.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 11-04-2007 at 11:36 PM. |
11-05-2007, 02:31 AM | #4 |
6>8 Plugless........
Re: "Dually" Noted
Truck is looking good 67 C-30!
11-05-2007, 02:46 AM | #5 |
Re: "Dually" Noted
I love 67-72 dually conversions
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
11-05-2007, 08:14 AM | #6 |
Re: "Dually" Noted
It does look right.
11-05-2007, 10:32 AM | #7 |
Its always something!
Re: "Dually" Noted
Thats a clean old truck. Its going to look good.
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed Member of the patina club |
11-05-2007, 11:00 AM | #8 | |
Re: "Dually" Noted
Thanks for the kind words guys. I went out today and measured the rearend for you. It is 58" plate to plate. If you are happy with your current ratio, there are companys out there that sell dual rear wheel adapters. It may save you money and fabrication if you have to buy a rearend weld mounts to make it fitn like I did. My original rearend had 5.38 gears, so I would have had to change everthing. Don't be afraid of the billet adapters. I've been running a set on my '69 C-30 car for years with weights higher than you could ever put on a pickup and they are rock solid. Here are a few places to get them. http://www.wheeladapter.com/DuallyAdapters.asp http://www.arrowcraft.com/
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
11-05-2007, 01:01 PM | #9 | ||
Re: "Dually" Noted
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
11-05-2007, 01:24 PM | #10 |
Re: "Dually" Noted
Since it's a '67, I am going to shave both the one on the fleetside bed and the stepside fender. I am going to come back put some kind of small markers on the stepside so I can see them at night. I just think the factory markers look too big and gauky to be clearance lights. I have a set of lights from the '97 C3500 I got my rearend from. I may put them in right below the body ridge which is about the same location as the they came on the '88 - '98 trucks like in the pic below.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 11-05-2007 at 01:25 PM. |
11-05-2007, 01:40 PM | #11 |
Re: "Dually" Noted
This is what I have in mind...
11-05-2007, 02:04 PM | #12 |
Official Site Guitar Shredder
Re: "Dually" Noted
67 C-30 thats one fine truck... i cant wait to see it all finished great work....
11-05-2007, 02:23 PM | #13 |
Re: "Dually" Noted
i gotta hand it to you, that will look great. again, AWESOME truck!
11-06-2007, 01:11 AM | #14 |
Re: "Dually" Noted
67_C-30- Thanks for all the help, had seen the dually converters in JC Whitney but didn't take them serious. I'll givee them another look. I'm running 4.11's now, was thinking more like 3.90 since I have the Gear Vendor aux. I have a couple of "before" pics I'll post if I can figure out how. Thanks again for all your help, your a gold mine
11-06-2007, 01:25 AM | #15 |
Re: "Dually" Noted
Figured out how to load these pics, everthing is "before" except the egine shot. Thats a new 427 Tall Deck. Am working on painting the cab and front end this week, will do the bed when I figure out how I'm going to do the dually....
hooberjon@yahoo.com "Life's Been Good To Me So Far" 1941 Chevy PU (new project, right out of the field) 1948 P/U: 350/700r4, Nova Clip,Chevelle rear, air ride suspension, custom door handles, custom firewall, custom dash, buckets and console, visor 1967 C20: 427 Tall Deck, Turbo 400 with Gear Vendors aux tranny, 5th wheel, 3500 bucket seats and console. 1996 Geo Tracker 2x4 1996 Geo Tracker 4x4 Last edited by 48 ish; 11-06-2007 at 02:24 AM. |
11-06-2007, 02:36 AM | #16 |
Re: "Dually" Noted
Two more
11-06-2007, 10:41 AM | #17 |
Luv the Crewcabs
Re: "Dually" Noted
That Motor look's Awesome the Way You Painted it up, Good Luck with your Project.....
Rick
11-06-2007, 07:02 PM | #18 |
Re: "Dually" Noted
48ish - that truck will look great in dually form! It should be hoss with the 427 tall deck and GV OD!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 11-06-2007 at 07:04 PM. |
11-07-2007, 12:31 AM | #19 |
Re: "Dually" Noted
Thanks guys...I just finished painting the front end tonight, I'll be sure to post more pics when I get all the bits and pieces back on. I got a good deal on a set of dually wheels (all 6) for $150, and looked at the adapters, I'm thinking I might go that route .
67_C30...how did you end up marrying the fenders to the bed? screws? bolts? what size/type? or did you weld them? ..
hooberjon@yahoo.com "Life's Been Good To Me So Far" 1941 Chevy PU (new project, right out of the field) 1948 P/U: 350/700r4, Nova Clip,Chevelle rear, air ride suspension, custom door handles, custom firewall, custom dash, buckets and console, visor 1967 C20: 427 Tall Deck, Turbo 400 with Gear Vendors aux tranny, 5th wheel, 3500 bucket seats and console. 1996 Geo Tracker 2x4 1996 Geo Tracker 4x4 Last edited by 48 ish; 11-07-2007 at 12:43 AM. Reason: grammer |
11-07-2007, 04:04 PM | #20 |
Re: "Dually" Noted
Lookin good!
11-08-2007, 08:27 AM | #21 | |
Re: "Dually" Noted
I welded tabs to the backside and drilled hole in the fleet bedside and bolted them on with (10) 5/6 - 18 bolts. The tabs are actually part of the stepside fender that I cut to contour it to the fleet bedside. There's a lot more pics and details on my build thread in my sig.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 11-08-2007 at 08:29 AM. |
11-09-2007, 10:57 PM | #22 |
Re: "Dually" Noted
Isn't the bed side double walled? How did you attatch the nuts?
