defrost hoses and blend door
Need to know best place to get defrost hoses. My blend door has not worked in a long time. It has a/c wondering about a fix other than getting a new one. thanks
Re: defrost hoses and blend door
I need the same, been to all the local parts houses, no luck. Even the chevy dealer here doesn't have them. I had an idea the other dat though, VW beetles use the duct work that "looks" like ours. I will check out this weekend. I am getting ready to measure the O.D and I.D. of the hoses and go see what I can find out. If this is a big no then maybe someone else will have an answer. Good luck and if this works I"ll be back.
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
I am a Referee of life.
Any of the BB vendors will have the hoses.You need to specify whether you have A/C or not.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
if you dont want to get if from a vendor then go to classsic chevy inc he has everything you need for these trucks. its in kings mountian
Anybody also had trouble with the blend door not opening or closing my wont runs hot air all the time had to install cutoff on fenderwell where acuator is.
