11-05-2007, 10:22 AM | #1 |
heat and a/c blend door
Anybody ever try to repair one.Took mine out awile back rod slips and turns by itsef. Wondering about a fix. thanks terry
11-05-2007, 11:11 AM | #2 |
I am a Referee of life.
Re: heat and a/c blend door
There should be a write up in the FAQ's on this.I've never done it before but I do recall a thread on it with a fix.Someone may be able to point you at it.BTW you can search krue he had done a fantastic job of trying to index the FAQ's.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-05-2007, 01:33 PM | #3 |
O K sounds good let me know. Searched krue coul not find anything yet on blend dorr i ll keep trying.
11-05-2007, 05:53 PM | #4 |
Born Psycho
i repaired mine over 15 years ago-long before i had a computer- and it still works great. i opened the case and took the flapper out, carefully trimmed off the rubber seal, glued the plastic back together, cut a small steel plate to fit the flapper,ground the plastic down to the pivot rod, welded the plate (verrrrrrry slowly so i wouldn't melt any more plastic), re-glued the rubber seal and glued the case. it took about a week overall to do it but i think it was well worth the time.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
11-06-2007, 05:16 AM | #5 |
I repaired mine ( about 10 years ago!).. similar to the method jerry moss used; except I used expoy resin with aluminum filings additive.... Most any boat dealeer has the expoxy.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
11-06-2007, 06:46 AM | #6 |
1997 GMC Sierra Ext 1965 Mustang |
11-06-2007, 03:41 PM | #7 |
Thats some good stuff there. Do you know the link on krues page for fixing blend door . thanks
