Old 11-05-2007, 08:55 PM   #1
paul5663
paul5663's Avatar
'59 Speedo drive gear for 700r4 ??
I bought a rebuilt 700r4 for my '59 but it didnt come with a speedo drive gear. I want to use the original speedo. Anyone know which gear to use (approx) using 18" wheels on rearend? If not, how 'bout a formula to figure it out? Thanks......Paul
http://67-72chevytrucks.com/vboard/s...d.php?t=229882
paul5663 is offline   Reply With Quote
Old 11-05-2007, 09:17 PM   #2
solidaxel
solidaxel's Avatar
Re: '59 Speedo drive gear for 700r4 ??
Do you still have the one from your transmission you took out of the truck?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-05-2007, 09:55 PM   #3
paul5663
paul5663's Avatar
No, unfortunately, I bought the truck minus the drivetrain.
Paul
Old 11-06-2007, 07:48 AM   #4
entourageguy
Yellow truck club
entourageguy's Avatar
found this
Speedometer Calculation Formula
The SAE Standard for Speedometers on American cars is set up so that the speedometer cable will turn 1,000 rpm at 60 mph or 1000 revolutions in 1 mile.
Simply multiply the rear axle gear ratio by the speedometer drive gear, divide that by the tire diameter and multiply this by 20.2 (a constant).
The following formula can be used to determine the correct speedometer driven gear.
Driven Gear = Gear ratio X Speedometer Drive Gear divided div. by TireDia = a
a X 20.2 = Number of Teeth on Speedometer Gear
Brian ...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 11-06-2007, 04:10 PM   #5
solidaxel
solidaxel's Avatar
Do you have any idea what gear ratio the rear end is, 2:00, 3:00, or 4:00
LS 3 4L70E
Old 11-06-2007, 04:15 PM   #6
solidaxel
solidaxel's Avatar
Do you have the gear installed on the mainshaft of the transmission, inside the tail shaft?
LS 3 4L70E
Old 11-07-2007, 07:03 PM   #7
paul5663
paul5663's Avatar
Well, the rearend is a Dana 36 w/ 2.59 gears.
Old 11-07-2007, 07:09 PM   #8
paul5663
paul5663's Avatar
Ooops! submitted before I was done w/ message! Anyway, thanks for replies...Brian, I will try it out.
Paul
