11-05-2007, 10:20 PM | #1 |
silverado SS 20" rims
will a set of Siverado SS rims that are 20"x9" fit on my 67 chevy half ton?
11-05-2007, 10:22 PM | #2 |
The master of disaster
Re: silverado SS 20" rims
nope dont thinki so man if i member right lug pattern it spaced differently
1994 Chevy Project in the works Life is like a jar of japalino's what you do today will burn youre a$$ tomorrow! |
11-06-2007, 10:18 AM | #3 |
they are six lug. just like my 67
11-06-2007, 10:19 AM | #4 |
My statement stays the same if all else test fit them and see
Or better yet get a tape mesure and do some mesuring mesure the center opening highth and width and then do you lugs top to bottom and left to right. But I am almost certain that they will not fit youre truck
1994 Chevy Project in the works Life is like a jar of japalino's what you do today will burn youre a$$ tomorrow! Last edited by bent; 11-06-2007 at 10:21 AM. |
11-06-2007, 10:21 AM | #5 |
Active Member
Lug pattern is the same but the wheel offset is way different, you may have to run a spacer.
'70 Chevy stepside, ECE discs & 4/6, '00 GMC ext. cab stepside, never ending project '07 GMC Crew Cab, 24's & 5/7 "We, the unwilling, led by the unquailified, have been doing the unbelievable for so long with so little, we now attempt, the impossible with nothing" |
11-06-2007, 10:24 AM | #6 |
this may sound dumb but where could you pick up a spacer?
11-06-2007, 10:27 AM | #7 |
Trey I have tried a set of 02ss wheels and i coulnt get them to fit on my 79 any ideas why
11-06-2007, 10:31 AM | #8 |
If the bolt pattern is the same I don't think the wheel will clear the bearing cap, but a spacer should correct that.
11-06-2007, 12:43 PM | #9 | |||
Union Electrician
Yes the patterns are the same, but the center hole will have to be enlarged for them to fit over your hubs. I would assume you could use a spacer instead(or if needed for the offset) but I would try to get them to first by having the hole machined out instead of spacers if at all possible, just my .02
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
11-06-2007, 01:26 PM | #10 |
Byrd is right on machining the hole. You could do it the opposite way too. Have the axles and spindles/hubs machined smaller so the wheels fit.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
11-06-2007, 02:53 PM | #12 |
chrome makes it go FASTER!
I have a set of z71 rims on my 69 and the offset is way wrong 1 1/2-2"
Rubbing on the wheel wells and the bearing cap problem. Spacers can be found at any tire/rim shop. Kinda pricey expect to pay $100 plus per pair. And I wouldn't use them for towing or racing.
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
11-06-2007, 02:53 PM | #13 |
Check e-bay "wheel spacer " for prices.
11-06-2007, 06:58 PM | #14 |
kinda thought that they'd look cool, so i photoshopped my truck with em.
my girlfriends' father has a trailblazer SS with these rims. im gunna try to convince him to let me steal his truck one afternoon so i can try em on and see how they fit, if he lets me, ill keep you boys posted.
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
11-06-2007, 08:56 PM | #16 |
silverado ss wheels will fit on it but with spacers. i got a set for my 69 but they didnt look good on my truck, so i got rid of them. and for future reference to 69halfton, trailblazers 6 lug is smaller. i bought a set of 20" torque thrusts that came off a trailblazer and the lugs didnt line up. the only problem i have with the 18x9s i have now is that when the truck is on the lift the grease fitting for the ball joint rubs on the inside of the wheel. when the truck is on the ground its an inch away. so the 20x9s will fit better...
08-07-2008, 09:27 PM | #17 | |
Thanks!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
