Old 11-06-2007, 12:54 AM   #1
SkylineNXS
SkylineNXS's Avatar
Window Removal...
I come back to this topic once again. I posted on here a while back about putting the windows in, and sort of remember, and now i cant get em back out. Can anybody help me out here? Thanks...
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 11-06-2007, 02:05 AM   #2
salazar44
65 - Chevy C10
salazar44's Avatar
Re: Window Removal...
Your talking about the roll up windows? If so, just remove the door panel from the inside, and slightly roll up the window so you can see the channel come up. Then you put the window in and position it in the window channel. I used some window caulk to keep it "glued" into the channel. I think this is what your talking about?
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 11-06-2007, 03:20 PM   #3
SkylineNXS
SkylineNXS's Avatar
Actually i want to remove the window along with the channel, thats how i put them in originally. I just cant remember how i got em in there...
BRAD
Old 11-06-2007, 10:15 PM   #4
badriand
badriand's Avatar
2 or 3 screws that hold the channel for the vent window on the top side of door and 2 screws on the panel toward the bottom middle remove those then slide the vent window out. I got my window out by rolling it up halfway then pulling the window up and over so the roller on the right side slid out then rolled the back one out. Next pull out. O yea easier if you remove the molding and felt also, felt has little tabs that hold it in place. Patience is your friend here.
badriand is offline   Reply With Quote
Old 11-07-2007, 01:46 AM   #5
SkylineNXS
SkylineNXS's Avatar
o damn, i though it was the other way around, with the vent window goin in first then the big window, my bad. Thanks, ill do it tuesday, appreciate it...
BRAD
