Tips on Installing Power Steering
I'm about to install power steering on 70 GMC and wondering if there is anything to watch out for or advice on the order of things to install. I took the pump,pulley and box from a 78 C20. Thanks
Re: Tips on Installing Power Steering
I would like to know also???
All Toys: 1971 C10 Fleetside - I needed it! 1970 C10 Stepside - Midlife Crisis 1969 C20 3/4 Longbed - Beast! 1966 Mustang Fastback - Daily Fun 1965 Mustang Fastback - Money pit! |
have ya got the pumps brackets? they can be pretty hard to find.
I have a 71 setup and a setup off a 86 Van...
I have the pump, brackets, hoses, double crank pulley and steering box.
then thats about all the help i can give you ive never personally done a install on one, just know thats a common problem people run into
Thanks Berencam for the info and hope your feeling better !!!
#9 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Swap the box and pitman arm.
Install pump and belt. Connect hoses, fill and bleed. Enjoy. If you have everything you need, plan on 2 hours of work. The pump brackets can be tedious, particularly the one bolt that goes through the engine mount. Beware though, that 70 model truck and your 78 donor use drastically different pump and brackets. The boxes interchange though.
