11-06-2007, 09:11 AM | #1 |
Camaro Club
What vendor carries a rear flip kit for 67-72
I have searched numerous vendor sites trying to find a rear flip kit for my 68 gmc and i havent had any luck. Summit racing only has them for 1973 and newer chevy's. Will the 73-87 kit work on my truck or will the narrow leaf springs affect that. Or if anyone has made there own flip kit and would like to let me know how you did it i would apprieciate it... THanks
JOtt |
11-06-2007, 09:23 AM | #2 |
Official Site Guitar Shredder
Re: What vendor carries a rear flip kit for 67-72
G.M.C Pauls has them, As would Wes with Classsic Heartbeat. You can however make your own. with new saddles moved on the bottom and just flipping your stock- u bolts although i would replace the u bolts... i have done it either way.. but i think the flip kit would be best.... as when you make your own ,there is alot of measuring and know how....the flip kit takes the guess work out of all that....tony....hope this may help
11-06-2007, 09:28 AM | #3 |
Camaro Club
i looked on Gmc pauls but i didnt see it. Maybe i just over looked it.
11-06-2007, 09:33 AM | #4 |
Camaro Club
well i just looked on Gmc pauls again and i didnt see it. I saw the bolt in c notch but no rear flip kit for 67-72.
11-06-2007, 09:47 AM | #5 |
CS23533 Front - Coil Springs - 3'' Set
FK10125 Rear - Flip Kit - 5'' Each 1309DJM Cal-Max Super Shock Each 1800DJM Cal-Max Super Shock Each 1-800-706-1127 Stylin' Trucks I just ordered all this two weeks ago and their price was excellent... Hope this helps...
All Toys: 1971 C10 Fleetside - I needed it! 1970 C10 Stepside - Midlife Crisis 1969 C20 3/4 Longbed - Beast! 1966 Mustang Fastback - Daily Fun 1965 Mustang Fastback - Money pit! Last edited by 70C10Step; 11-06-2007 at 09:47 AM. |
11-06-2007, 11:45 AM | #6 |
Camaro Club
Thanks for the info. I'll check stylin' trucks out
11-06-2007, 11:49 AM | #7 |
Paul has it..im positive,thats were i got mine....8 years ago.... i looked and didnt see it listed but he has it...
11-06-2007, 01:13 PM | #8 |
Total cost for the flip kit, 4 shocks and springs was $459.00 and that included shipping.
All Toys: 1971 C10 Fleetside - I needed it! 1970 C10 Stepside - Midlife Crisis 1969 C20 3/4 Longbed - Beast! 1966 Mustang Fastback - Daily Fun 1965 Mustang Fastback - Money pit! |
11-06-2007, 02:30 PM | #9 |
Watch out for your cornhole !
I usually make my own flip kits. Your local trailer parts supply house will sell you a pair of axle saddles for under 20 bucks.
Even Northern Tool and Tractor Supply stores stock them. You can use a Home Depot protractor to set up the pinion angle before you stitch the saddles in place.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 11-06-2007 at 02:32 PM. |
11-06-2007, 06:08 PM | #10 |
Camaro Club
Tx firefighter
I was told its not a good idea to make your own because it will move your axle forward. The flip kit has an offset hole for the center pin on your leaf springs |
11-06-2007, 06:49 PM | #11 |
In my opinion, the reason the commercial kits offset the pin on their flip saddles is too gain a bit of driveshaft leeway when lowering it that far. When you drop one that deep, the yoke slides further into the transmission. You should either shorten the driveshaft a bit to compensate or offest the rearend rearwared a bit.
I just make sure my rearend is centered in the wheelwells for aestetics and build the driveshaft length as needed. It's worked well for me. Don't get me wrong though, I've installed countless Belltech rear flip kits on 88 and newer trucks. Thats for people paying me for the work who want quick, pretty results. For my own junk though, it's grind, weld and paint, then fold my money that I saved in half and stick it back into my wallet.
11-07-2007, 06:35 AM | #12 |
Camaro Club
Tx Firefighter...
Do you have any pictures of the trucks you've made the flip kits for. Because if it really does look ok then i'll just save myself some $ and make mine. |
11-07-2007, 07:58 PM | #13 |
You can make flip kits work from other vehicles. Really the perches fit alot of rear ends. I've used camaro ones on ford rears and you just make them work. Its not really hard. We get our axles shortened fairly inexpensive and 1 day service. like $75.00
Mike Last edited by mbgmike; 11-07-2007 at 08:00 PM. |
11-07-2007, 08:25 PM | #14 |
The 73-87 kits are easier to find & it doesnt take much to make them work...
11-07-2007, 10:27 PM | #15 |
Camaro Club
Corn
Do you know what it takes to make the 73-87 kit work? Also i was wandering if 73-87 front lowering coils will work because summit racing carries there own brand for $73.95 for 3 inch drop. |
11-07-2007, 10:38 PM | #16 |
Yes & yes. I have both on my 69. The flip kit is very easy to make work. Just trim a notch on each corner so it fits in the narrower perch. I have 3" Ground Force (summit 73-87) springs in my truck too...
11-08-2007, 06:38 AM | #17 |
Camaro Club
Ok that is great because I can save myself a ton of $$$ by using the 73-87 parts.
Corn Your truck sits pretty level doesnt it? I want my truck to be pretty close to level. Or atleast as close as i can get it |
11-08-2007, 08:40 AM | #18 |
Licensed to Thrill!
Here's what StylinTrucks.com shows for our trucks
http://www.stylintrucks.com/sn.aspx?...-30=Suspension And here's the flip kit. http://www.stylintrucks.com/parts.as..._prod_ids=3339 DLB |
11-08-2007, 08:50 AM | #19 |
Questionable
I wonder why Stylin' Trucks changed their name from Stylin' Concepts?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
11-08-2007, 09:08 AM | #20 |
I do not know why they had the name change but the service was great and my parts where on my door step in a few days. I paid about $130 for the flip kit made by DJM... I felt like this was a fair price... Summit Racing wanted $165.00 for the same kit...
11-08-2007, 05:17 PM | #21 |
Camaro Club
I'm pretty sure i am going to use the 73-87 parts on my 68 because the flip kit i found is only $84.75 and the 3 inch lowering coils are only $73.95 and that is cheaper than any of the others i have found.
11-08-2007, 07:43 PM | #22 |
I understand you want to save money, I am trying to do the same thing with my 383 build....
11-08-2007, 08:34 PM | #23 |
I have a question.. What if I didn't want to flip the rear end but still wanted to drop it some just to level it up a bit .. is there a home brew option? I have a torch and welder handy.. it is a 3/4 ton and the springs are huge! .. can I remove some of the leaf springs? or move the cups up on the frame and just use 2 bolts instead of 4? any free type remedies.. .
Thanks and sorry for hi-jacking this thread but I thought this would be a good place to put this with out opening up a whole different thread topic..
Jeff 1967 GMC 3/4ton LWB, Orginal Straight 6, 4 on the floor Project truck |
