Anybody able to id this engine?
I'd like to buy a truck but I don't know what is the engine. Anybody are able to identify this engine?
'71 Custom/10 Deluxe LWB '71 Custom/30 Deluxe Dually |
Re: Anybody able to id this engine?
grab the numbers off the back side of the block, think its on the drivers side just behind the heads. if i had to guess, id say 307 or 327
thats a oldsmobile engine 267 maybe
nickle and dime |
No I'm not able to see at rear of block to ck number and I don't have any num on front of the block on the passenger side. I have take a picture of the front of the block between block and water pump. The front of the block is not straight. And the oil filler neck don't pass true the intake manifold. Check this pictures!
Formerly yellow72custom
That is most definitely NOT a Chevy engine. It is some sort of GM engine (it has an HEI distributor in the back), but I have no idea what it is. Probably some type of Buick, Olds, or Pontiac engine (I believe Caddys has a front-mounted distributor).
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
correct most caddys that I have seen have the dizzy up front Id have to agree with c-downs and royo both very knowledgable guys and c-downs is very into the old time rods..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
It's the air up here
Not a chevy v-8. Maybe olds or pontiac, buick. Looks like a big block maybe with the spark plug spacing. Or are all the other gm v-8's plugs spaced like a big block?
1971 cheyenne k10 4 speed np 205 454 BB factory a/c ![]() Never drink down stream of the herd! Eric |
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
![]() Join Date: Oct 2006
Thats an OLDSmobubble. FOR SURE. The oil filler and water neck give that away. So does everything else about it. What is it in?
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
Hi woodridge why you say that's a77-88 350, I'd don't make the link on the site taht you give
To The Levy
I would say oldsmobile also , without better numbers, hard to tell what year and what exact size,
#13 |
I have a radical idea!
Its a mid to late 70's Olds 260, 350, or possibly 403 judging by the GM Corporate Blue paint. The only I know absolutely without a doubt is it is an Olds engine.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 11-06-2007 at 07:23 PM. |
#14 |
I'm a poor spectator
Valve covers are another give away.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
#15 |
Born Psycho
![]() Join Date: Feb 2001
i agree, it's an oldsmobile motor.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
#16 |
Old Skool Club
![]() Join Date: Jun 2001
My nephew had an '80 diesel Chevy, and pulled that engine (Olds based) and replaced it with an Olds V-8.
What truck are you looking at. I haven't seen anything in any comments about what it is. Is it possible that it was originally a GM diesel? Knowing what you're looking at may help you know why the engine that's in it, is there. Another clue may be a second battery mount that doesn't have a battery....etc. I wholeheartedly agree that it's an Olds engine.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#17 |
The truck is a 67-72. You can tell by the heater box and master cylinder!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#18 |
Step Brother
#19 |
Woddbridge have the right answer after decoding the casting number it's a 557752 3b block=Olds 350 from 77-80 year. Badly I'm looking for a chevy 350 not olds, parts appear to be difficult to found if you compare to Chevy. The truck is a 1967 long stepside fluo green!! Thank's for your research.
'71 Custom/10 Deluxe LWB '71 Custom/30 Deluxe Dually Last edited by syncrov69; 11-06-2007 at 08:25 PM. |
#20 |
I didn't have much time to fill in the post after I found the casting # on the site I linked. It is most definately an olds engine and the casting number ID's it as a 77-80 350.
2A '75-'81 260 Solid main webs for 2A's only? At least for '76. 2B ??-'81 260 557751 Windowed main webs. Windowed main webs for 2B's only? 3A '79 350 3B '77-'80 350 557752
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet Last edited by woodridge; 11-06-2007 at 08:29 PM. |
#21 |
I agree it's an Old's engine I had one of those in a 442 i bought way back when.
Willie
1972 K-10 L/B 4x4 Matching #'s 350 4 speed from the factory. P/S P/B 1981 GMC 1/2 L/B 4x4 one owner truck. 4" lift 2004 Dodge Cummins Diesel 4x4 Q/C S/B 1986 Dodge D150 L/B 2WD |
#22 |
I've seen a couple of them in 6 7-72 trucks before. A junk yard near me had a real clean pick up and when I lifted the hood, there sat an olds motor. I've seen one other also.
#23 |
The K-2500 in my avitar had a 455 in when I bought it. Normally, these are killer motors but this one ran like a dog and always hot. A 400 small block now resides under the hood and runs much better.
#24 |
#25 |
oldsmobile motor. you can see by the pictures they fabbed in some different motor mounts to fit in the chevy truck
