tranny fluid type
could type F tranny fluid be run exclusively in a th 350 with a mild shift kit
To The Levy
Re: tranny fluid type
WHY????
why would you want to put a ford fluid that is for fords, dexron 2 or 3 would be what you want , and should be readily available at every auto parts store you can find, I would guess even your grocery stores will stock it, If my memory serves me, and maybe someone can correct me, the friction material is in the ford fluid and on a gm it is in the material of the bands and clutches, I suppose it would work , but I would wonder why you would even want to use it, I personally would stick with what it calls for , dexron type fluid |
its all about the +6 inches
OI have heard tranny builders say it is better stuff, but they also said you had ti use exclusivly the F stuff and never mix the two.
If it's a fresh rebuild, I say get mobile1 dextron. |
![]() Join Date: Dec 2006
Yeah,what LM says. FWIW,I used to work in AAMCO shops and that's all we used, shift kit or no.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
B&M says to use type F after thier shift kit is installed.
Type F is almost the same thing as B&M's "trick shift". Ive always had good luck with type F with shift kits...
