Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 11-06-2007, 07:54 PM   #1
1-tonmudder
Modern day Fred Sanford
1-tonmudder's Avatar
TH 400 kickdown
Th400 kickdown bracket and switch from a 86 K-30.$35 shipped.
1-tonmudder is offline   Reply With Quote
Old 10-14-2008, 10:06 PM   #2
1-tonmudder
Re: TH 400 kickdown
ttt
Old 10-25-2008, 08:04 AM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: TH 400 kickdown
I'm interested in the kickdown, do you have any more pictures of it? Does it have the wire harness or connectors?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 10-29-2008, 04:53 PM   #4
1-tonmudder
Re: TH 400 kickdown
Here's some better pics.
I should have the harness for it also.I'll just have to find it.
Old 10-30-2008, 01:33 AM   #5
MylilBowTie
Right turn Clyde
Re: TH 400 kickdown
I'll take it but would like to get the harness with it.
Old 10-30-2008, 03:19 AM   #6
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: TH 400 kickdown
Making a harness for this switch is rather easy. The same connector that plugs into the internally regulated G.M. alternators from the early '70's through the mid - late '80's will hook right up to it.
Run one lead to a "keyed" or "ignition on" power outlet at the fuse panel and run the other lead through an already existing firwall grommet (think speedo cable grommet) down to the terminal on the tranny. If your fuse panel utilizes the blade type fuses (A.T.O.) then you should be able to use one of these connectors availible from NAPA
This one is for "ign" connections on the fuse panel
And this one is for 'bat" power connections i.e. power at all times.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 11-05-2008, 04:08 AM   #7
MylilBowTie
Right turn Clyde
Re: TH 400 kickdown
How would you like payment?
Old 11-08-2008, 01:39 PM   #8
MylilBowTie
Right turn Clyde
Re: TH 400 kickdown
Got the payment sent out.
