Old 10-07-2002, 01:55 PM   #1
KP1972
KP1972's Avatar
Gauge testing
How can I check to see if my idiot lights are working and connected???
1972 Chevy Custom/10
www.PictureTrail.com/KP1972
Metroplex Muscle Car Club
www.PictureTrail.com/DreamCarArt
KP1972 is offline   Reply With Quote
Old 10-07-2002, 02:57 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
With the ignition on and engine not running, the idiot lights should be lit. They should go out when the engine is running.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 10-07-2002, 03:00 PM   #3
KP1972
KP1972's Avatar
Fred, they do NOT light up at all. What is my next step?
Old 10-07-2002, 03:11 PM   #4
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
1. Be sure bulbs are good (sounds stupid, but it happens!)
2. Ground oil sender wire at block, light should light (I may have that backwards, you may have to un-ground it)
3. Check 2 4 amy small fuses, one at battery, one at firewall, they blow real easily, always disconnect battery if messing under dash)
If these steps don't work, call back!
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
