Paint question for the restorers
I've been collecting parts to turn my truck into an AC truck when I get ready to do the big tear down and I was wondering what you guys are using for paint to make the inner and outer suitcases of the system look factory fresh. Some of my underdash pieces aren't quite the same color as others and the case that would go under the hood has been painted green, so I need to strip and respray it. Any suggestions or pics of stock AC systems would be appreciated.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
Re: Paint question for the restorers
Under the hood box is hard to match since it had fibers showing in the color.I don`t think there is a "correct" way to do the heat system and be one color.I know the inside pieces are mixed colors anyway.One piece looks o.d. green.I guess I like a satin black under the dash.
Thanks Tim. I didn't think there was anything I could do with the outer box, but I figured I'd ask. The o.d. green piece was actually the piece I thought was faded or something. I guess I'll leave that one alone and respray the other pieces in Krylon's semi flat black.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 11-07-2007 at 10:45 PM. |
I`m going to pay more attention to that o.d. piece.I`m not sure if all mine are that way or whether all are like that.Maybe heat turned them?
I sprayed my outer box with duplicolor "vinyl dye" and it turned out pretty good. I'm not sure how it will hold up to the elements tho.
I'll get some pics when i get home. ![]()
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
i lightly sanded my outer ac box and coated it with several coats of satin clear. looks like new
common sense isn't so common anymore |
The outer box looks like a faded grey color- I used on cast coat color on both of mine- available from NAPA as Cast Iron Grey - it allows the fibers to show and makes it look like new- hit it with some clear and it really pops.
I have a radical idea!
I did something similiar on my GT-37 and it turned out pretty good as well.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
If anyone gets around to posting some pics I'd appreciate it. They all sound like good ideas.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 11-08-2007 at 05:53 PM. |
[her
common sense isn't so common anymore Last edited by wibilly; 11-08-2007 at 07:58 PM. |
