Old 11-07-2007, 10:01 AM   #1
1984Silverado4x4
Idle speed
Is there a way to lower the idle speed when the choke is on.
Cause mine is running way to fast when the idle is on and tapping or even stomping on the gas pedal dosent turn the choke off, you have to wait for the engine to warm up
Its no disgrace being poor. Its just inconvenient.
1984Silverado4x4 is offline   Reply With Quote
Old 11-07-2007, 02:06 PM   #2
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Re: Idle speed
What carb? Generally there always is adjustment on fast idle speed, tis a small screw on the passenger side of the carb that "rides" on the fast idle cam, electric choke usually hides it from direct view. That screw acts similar to the main idle speed one near the throttle bracket - tirning it in raises RPM, backing it out slows the engine down.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
