Old 11-07-2007, 11:37 AM   #1
outlawc
FS, Complete 350, 350 turbo trans.
I have a good rebuilt 350 with a rebuilt 350 turbo trans. I have had this for a project and was going to put it in my Blazer, but with the way gas prices are supposed to go up I am going to rebuild the 4.3 instead and keep the overdrive.
Alittle info on the motor. I dont know how many miles are on the motor but I pulled the pan and everything is fresh, crosshatching on the cylinders show almost no wear. The guy I bought it from said it has less than 2000 miles since built and should be over 300 hp, runs very strong. The cam has a mild idle, ( dont know manufacturer). The motor is complete, carb to pan. ( Rochester carb, stock HEI distributor, water pump, starter, Taylor plug wires. Motor does not burn any oil, plugs are showing a clean burn and no oil consumption.
The block casting #s are 3970014, casting date is L 27 73 ( Sep.27, 1973 ).
The block stamping # is T 1031CMR.
Heads casting #'s are 3890462.
Head date code is L 15 6 ( Dec. 15, 1966 )
These heads are 327 double hump 62 cc chamber heads , (no accesory holes) and were rebuilt when the motor was. I was told they are Corvette heads but without pulling the heads to check for the 2.02 valves I cannot say for sure. If anyone is serious about buying I can pull the heads to know for sure.
Transmission is a fresh Turbo 350 with new torque converter. Came out of a Chevy truck.
I will sell the motor for $ 600.00
I will sell the trans for $ 300.00
If they sell together $ 800.00
If anyone has any questions feel free to ask.
outlawc is offline   Reply With Quote
